Novadex-Keep an eye on here/ebay etc.
You could also look at the CatCams range.
I got a AST2 off here a while back.
Yet to fit it to my 1400 yet tho, Lol.
Dan, its only the mild cam (NVO62) ive got. Im taking it out tomorrow because its just bad to drive. All the timing is fine, it misfires and hardly moves from cold in the morning, had tech 1 on it (i work for vauxhall) doesnt show anything. What do you mean dialled in? I was told its just a straight swap pretty much as its only a mild cam. Anything you recommend trying?
Sorry, just realised its not my thread and im going off topic
Seems V. strange that, if anything i'd imagine a Sri engine coping with a cam much better than a e16se due to it having a Map sensor and no air flow meter for the cam overlap to mess up.
You sure its a NVO62?
That should run and idle fine as its for an injection engine.
I know you said the timing is fine, but i would definently re-check it.
By Dialed-in he means set the cam timing up with a Vernier pully.
Can anyone recommend a cam for a 16sv engine standard apart form air filter.
