look on the SBD site, it tells you all you need to know about countersinking the bearing caps
ok i take it that is whats needed.Quote:
"Use a generous chamfer on all bolt holes (1mm)."
bruce
told ya you needed to counter sink it :p
its to stop the cap which has sharp edges from cutting into the bolt which would weaken it
No you need to put a chamfer onto the cap to match the bolt (the bolt is shamfered to avoid the sharp corner that caused the standard bolts to crack and the head fall off when overstressed in use). Match chamfer to chamfer...Quote:
Originally Posted by m.d.
