I intend on getting a set, or getting a set of low end coil overs with yellow springs, but I'm probably gonna get better brakes first.
i'm going to ask you a serious question. do you want it to look cool when it is parked or do you want it to handle well???
if cool when parked, chop the fcuk out of the springs, clamp them down or whatever................
if handle, then i'd say that there's probably a lot of fairly ropey roads on malta as well as some good smooth tarmac... and for spirited driving i'd say don't go below -60mm. also remember to trim the bump rubbers on the front struts.. if you can, get some shorter rear dampers, or they will bottom out..
Cut springs are awesome, I chopped the ones on my k10 micra in half and apart from them falling out when I jacked it up they where awesome :)
"Fairly ropey roads and some good smooth tarmac" in Malta? Are you high? Other than pot holes you can bury a person in, there isn't much smooth roads. The only smooth roads we have are (sadly) where "important" people drive through. Example, when the Pope came here, they re-surfaced all the roads he'd be driving over. But they forgot all about the others, but that's okay. And nah, I'd only lower it from the back. It's low at the front from the weight of the engine.
