typical, I never know which engine code is which engine!
optimising the ign timing properly (and to some extent the cam timing) should be done on a dyno. Timing is generally advanced until there is no further increase in torque at a given load/rpm. setting up base timing and book figure for lift at TDC is a great starting point and probably 98% there...but its often finding that 2% that is the difference between a good engine and a great engine. Anything else is just assembled.
base ignition timing figures should be the same, as is the method of adjustment, regardless of cam position. after each adjustment of the cam, the base timing should be re-set...or you will never know what gain/loss is from the cam and what is from the knock on effect of timing change.
im interested in how the timing is set on the 1.6 inj. is there a feature to lock the map (at say 10deg) so that the trigger can be aligned dynamically to the crank with a strobe?
with a sharp increase in timing below idle speed and a lot of retard after means that there isnt really a point where the map is 'steady' perhaps these primitive GM ECUs dont really use 'maps' ? i have never bothered with them.
for this reason, TPS and idle speed have to be as the book to give a decent figure..or it will give you a false reading.
the ohv can be leaded only, but all ohc engines run on unleaded iirc. the trick is to look for an asterix on the engine no on the block.
i used an X reg(81/82) donor engine for my 1.2+1.3=1.4 and it ran brilliantly on unleaded
the std way to time the e16se is to unplug the tps & short out the connections with split pins, thentime it to the mark with a strobe thenretard it a couple of degrees & test it to see if it runs right.... seriously... the main issue is that the same trigger in the dizzy is also the trigger for the injection, so timing is rather important. i've often thought of rigging up a 2nd trigger so i can time the injection differently, cos it would definitely run better if they were separate
same could be said for the SPI Corsa. it porbably would run better, but not worth the effort. the easiest way would be to put a 2 point trigger on the crank for the injection, and use the distributer purely for ign trigger. If the std engine is batch fire the gains would be minimal as theyre not really syncd to the valve openeing anyway. With each adjustment you would be offsetting the whole 'map' by the same amount so where you might get a gain at peak HP, you will loose out mid range and vice a versa.
anyone who is after such gains would fit standalone management or find gains elsewhere.
