Mike.. Mr muscle oven cleaner, followed by your mum's dishwasher.. You know it makes sense, but the tea cups might taste funny for a couple of days..
Its enough to make you want to kick something when you find out a bodger was there first...
Fair enough
Right so, got a new pump this morning...
However, the old one Ive got had take off for oil cooler, a new one he was supplied with the car has no take off for oil cooler but fits my XE block & crank fine? With regards to a relief valve type affair though, well there isnt one on the new pump???
Confused.net/very
Is it a case of simply putting a sandwich plate on my new & Im away as I could do with getting this bottom end tied up & done ricky tick now.
EDIT: Looking at 2.0 8v & 16v oil pumps on the FAI parts catalouge (website) they all look the same as to what Ive got here?
Yes swap sandwich plate to new pump if you want a cooler, just use the long bolt that goes through the middle of it. Or if you're not bothered about a cooler don't bother
Relief valve, take the one out your current pump and fit that?
