took some pics today.
had a quick look for a fuel return and couldnt see one, raining now so couldnt look and longer. where should it be on the carb?
heres a pic of the fuel pressure regulator
http://i240.photobucket.com/albums/f...00721-1622.jpg
and one of the coil any ideas what this would of came of? Sr nova? would like to replace this as looking a bit worse for ware
http://i240.photobucket.com/albums/f...00721-2020.jpg
thanks folks great help so far
well that coil definitely isnt a 1.4sr one, looks more like a 1.2 type coil
Coil looks the same as my 1ltr one
ummm is a strange setup :)
how would i know what the carb inlet is of? or is it definatly a sr item. would it be worth while sourcing an sr coil? would it make any difference? or would the wiring on it be deferent?
again apologies for all the question
if the coil works it works, changing it will achieve nothing. its is fairly certain that if its a sr carb its an sr inlet
it misses a bit so was goint to replace it and leads and get a timing light on it to make sure dizzy is right.
what do you think about the fuel pressure reg would it be better of using the proper fuel pump?
if it was me i would revert to the standard pump and fuel line set up
ill have to eake a look and see then if there is a fuel return. if not is it a matter of running a line from were it is on the carb to the tank? also where abouts on the carb would the return outlet be?
tanks again for the help
found it there and its blocked of with a screw in the end. is it just a matter of running a line down to the tank? have to see if i can sort out a inlet in the tank for it tho
