What about the fuel pump relay dosent this cause these symptoms if its goosed?
No, on an XE the pump will be triggered upon cranking when the crank sensor sends its signal to the ECU.
I fear it could be an earth issue as you were having battery probs at nats & yet your alternator has been over charging has it not?
What earth strap is on the gearbox? A GM braided copper one?
Definately. he says its been swapped though. But a sedom used one from the depts of a toolbox isnt always a safe bet.Quote:
Originally Posted by damen
but how would it kill the spark? the usual bodge on a fuel pump relay is to simply pull it out & bridge a wire across the terminals, and the sparks aren't affected
True best off with new as there not expensive from vaux.Quote:
Have you maybe got a blown fuse, I'm not really up on the 2.0 xe's but I had this happen on my old xe combo van.
Crank sensor switches both.Quote:
Originally Posted by mowgli
ECU cant do much if it thinks the engine isnt being cranked
lol yeah craig , was having battery probs at national day , but that was the earth that snapped in the boot ,
Have also fitted a brand new battery aswell
Gearbox earth strap is a newish one from a motorfactors, and batt to chassis earth is the same , injector rail earths are good , and alternator earths are fine as have fitted a new alt aswell :) to cure the over chargining
Just Hoping the overcharging hasn't fried ecu
well it was ecu , andy came down , and tried mine on his , no start
tried his on mine and it started , so rickardo met up wth stupot and got me another which andy then ran me to collect, big gay hugs to all 3 of you :thumb:
Nice one riggy glad you sorted it thought it sounded ecu related tbh.Quote:
Originally Posted by Riggy
