Would spacers help the brake clearance problem???
not too sure ad when i tryed them it was the caliper hitting the inside diamter of the wheel ,
Probably not then
willwood do a 236 mm 4 pot kit that should fit yhey also do 256 mm but not sure they will fit rally designs stock bothe its were i got my 280s from and im well impressed loads better than v6 stuff
it would be pretty cool if you could get 15" 3 SPOKE REPLICASlol
Some 236mm 4pots would be good enough imo
cant see a 236 kit , but there is a 247x20 kit , that might just fit £302.50 plus pads and hoses
Might be worth an email to see if you can use 236mm discs instead, as all the kit is discs and calipers by the look of it
With you on this Riggy i think the standard wheels with the car slammed looks TOP:thumb:
You'll get some scary tyre roll on them with a c20xe in
Matt..
