btt
btt
i thought ollys engine was standard bar some cams and rod bolts
Yeah, it is pretty much
Engine:
-20XE, Late 2.0 16v DOHC engine
-Jenvey 45mm tapered throttlebodies with MBE967-ED management
-Kent AST1612 Inlet & Exhaust Cams
... Inlet 260 duration / 10.08mm lift
... Exhaust 260 duration / 10.08mm lift
-Underslung throttle linkage
-90mm polished trumpets
-Lightened, skimmed & balanced flywheel (5.1kgs)
-XE Cream Injectors
-SBD Coilpack & holder
-NGK Super-4 plugs
-ARP2000 conrod bolts
-FSE Fuel Pressure Regulator (set at 4.5 bar / 62psi)
-Motorsport inline fuel pressure gauge
-ITG Mushroom filter
-Breather mod carried out
-Helix 6-paddle clutch friction plate
-Helix heavy duty pressure plate
-Helix clutch release bearing
Still a farking good solid engine that has had no problems since day 1, with 23 trackdays of 8k revving in it! :D s
Cheers Olly and its still going strong.
thank you
x x
btt
btt
Would you consider splitting it and selling bits seperately?
I think you're gonna have to Chris, I coudn't shift mine in one piece for love nor money, but I cleared all the parts when i broke it within a few weeks :)
im in no real rush but it is just sitting in the garage and not been out for 3 weeks.
Well it should be in the garage.
as above only real way of getting money back is the split
