cheers dude..
i just fancy building an engine before i buy the shell for it to go in.. then theres no messing about... wel not as much
cheers dude..
Do those cams need any other engine work (pocketed pistons or other bottom end bits, or different sprins / lifters)? I've currently got a piper fast road cam and fancy a bit more power. Engine is on twin 40s, which I think I may have to have set up again soon anyway, so may as well do any other work now before that is done.Quote:
Originally Posted by Stuart
Has anyone used Catcams? Interested in their 340 cam, too.
What's a decent exhaust manifold for that spec engine? Does an aftermarket one make much difference on these engines?
Cheers :thumb:
No, the AST2 and Piper BP300 do not require any additional engine bits. I know the Complete kent kit will come with some Kent "Uprated" lifters and stiffer springs - But neither are a neccesity. Infact, the Kent lifters have much lower quality casting compared to the GM ones - I stuck with the GM items and chucked the kent ones away.Quote:
Originally Posted by teej
Although i've just said neither require any other modifications, there is no point sticking a camshaft in that has a powerband of 3500-8500 when your standard bottom end isn't going to be too happy revving in excess of 8k. As a bare minimum i'd suggest fitting some ARP rod bolts if you're wanting to use the full powerband that the AST2 or BP300 offer... Also, if your wanting a daily driver - even the AST2 is a bit poo under 2-3k, although you can compensate for this with the carb setup.
Go for a cheap Ashley 4-1 manifold, mines still going strong, cheap as anything .
340!!!!!! feckig hell what are you after? lol
305 is about the max I'd go personally.
If your carbs need "setting up again" then a) they werent done by someone who knows what carbs are and b.) you need to make sure the spindles arent bent from the throttle pedal straining the linkage
340 is the cam code, and doesn't refer to the duration. ;) After a bit of further reading I agree it might be too much (311, 4.6), but could still like to know if anyone has used it. Info is on the Catcams site.
I don't know for sure who did the webers when the engine was built. It was bought as a "spare" race car, and hasn't really run in anger in two years, and very little in the while before that. I suppose it's more of a check than anything, but something I'd like to get done as I've got it back on the road now.
