Where are you?
Where are you?
wakefield, bout 5 minutes away from junction 40 m1
They are also starting to demand good money ie £100 upwards. Mk2 cav's had them in too. Std Mk1 astra ones had the most power.
you could probably buy a old mk2 Astra for around the same money as the 1300 engine then
doubt it any car now you can weight in for £180 :roll:
there was a mk2 asrta 1.3 for sale around the corner from me for 150 so bargins are stil about
bangerbrian - 1300 would be a straight swap normally, but as youve got a 1 litre shell ive got a feeling the front engine mount is different compared to the rest of the nova's, think it needs to be moved down an inch and a half, might just be for the xe mod tho, im not sure.
Not exactly sure but I think the shell used to have a 1400 in it but that was blown and had a 1000cc in, Thats what i can remember....
you need to move the engine mount for a 1ltr, you just have to use the engine mount off the 1300 - also you'll need the shafts from the 1300 as 1l shafts are different
You just use the ohc mount don't you? No welding?
I think thats what Draper meant to say?
