Looks awsome down that low!
Wings look good as well :)
That looks evil as feck!!!!!
You think you have come but i know i have all over the lap top bugger! lol lolQuote:
The general idea its self i like....but in reference to the top right pic especially the 'weld' part (and please correct me if i'm wrong) you will need to be very careful about how you go about the welding the extension on given the extream heat transfer caused when good penetration is achieved (you can't piegon sh+t it on if its essentially holding the hub/wheel to the car) and the chance of blowing holes in the shock body that welding would cause (i don't think Olly wants to be buying new shocks for experimental purposes! lol)Quote:
Originally Posted by corsakid
This is only my opinion and i'm not an expert in exactly what is in that part of the shock but i bet it doesn't take kindly to that sort of heat and neither would the seals ect so not 100% sure :confused: :confused:
hahahaha thats so sexy.
Adding on to the welding bit, lengthening that bottom part will also mean that more stress is put onto the weld/bottom of the strut (think of it like a lever point....)Quote:
Not sure how much your planning on changing it though, few mm should be 'reet.
Id be tempted to leave the standard bracket on the shock body, and then weld an extension piece on the end, drill two new holes for the bolts. That way you have plenty of thick metal to play with, and could even cut off and start again if something went wrong.
Like so:
http://img.photobucket.com/albums/v8...w/shock111.jpg
If you will be adding enough metal to drill new holes in that is.
James - we (Me & Kris) totally agree with you, and also mentioned about the problems you could incur when welding the shock body itself, and as you say - I wouldn't like to do this.
I was thinking like Adams diagram, but as he's stated... if we're only looking for mm, then you'd struggle, as the hole is 10mm in diameter I think... so you'd need the "tab" to be at least... 14mm in width (at a minimum)
hubba hubba me like's.
I wish you would stop raising the bar as i will never reach it now gggggrrrrr.
that looks sweet :thumb:
with the options on the shock/spring probs would it be posible to elongate the holes on the hub or the shock and run a spacer to give it more support?
might be a rubbish plan its been a long day:tard:
welcome to man sized lowness mr olly
