Took the inlet down and got it welded..
http://i6.photobucket.com/albums/y23...letwelded2.jpg
http://i6.photobucket.com/albums/y23...letwelded4.jpg
http://i6.photobucket.com/albums/y23...letwelded3.jpg
Should i paint it while its off?
So with that done it can go back on, the the pipes then the rad and water pipes. Cut a bit of stainless tube for the water system. And run the thing up.
Next, i bought these last week and they turned up today..
Not to happy as they turned up in a bag, saying they'd been re packed by DHL, think the hose is damaged on the back cause of this...
http://i6.photobucket.com/albums/y23...oodbrakes8.jpg
http://i6.photobucket.com/albums/y23...odbrakes10.jpg
Damaged hose...
http://i6.photobucket.com/albums/y23...oodbrakes9.jpg
Started to strip them to clean them up as they are minging, pads are low too so need replacing.
http://i6.photobucket.com/albums/y23...odbrakes15.jpg
http://i6.photobucket.com/albums/y23...odbrakes13.jpg
What the pads have on the back... Any one know what pads i can use?
http://i6.photobucket.com/albums/y23...odbrakes14.jpg
2Sets of discs, one drilled and grooved and one plane.
http://i6.photobucket.com/albums/y23...odbrakes11.jpg
for pads check out rally design, they do loads of brake parts
They always send stuff to me packaged in wilwood boxes so they should be able to help you out, seems they get through a lot of it! lol
They aint that cheap tho, plus i have no clue what pad it uses so will take ages looking thru all the pics..
Give them the numbers off the back of your pads and i'm sure they'll help you out, have always been helpful if i'd had any problems.
Whats the plans for the calipers Benn? a good bufty polish?
I'll have a go with that Mk.
Gra, good paint up, new pads and disc's then fit and use.
what size discs will you be running?
How Much Did You Pay For That Welding ?????
Benn, they are Midilite, 280mm discs I assume?
these are your options, I recommend Q compound
