No sh!t lol. lmao @ tree roots!Quote:
Seriously look at a "MICRO DIGGER"
Not a mini digger.
http://www.google.co.uk/imgres?imgur...ed=0CDcQ9QEwBA
30" wide.
And not tall at all.
I know what id be doing, hiring one of those, and a skip on the drive.
Just FFS get the deeds out with the pipes and cables etc lollollollollol
Good stuff, just need to bear in mind where the external damp course to the main building. If your new floor level is going to be below it you might have fit it out with tanking to stop any possible moisture ingress.
right. LEE. i am now going to put in some important facts...
1. do not use a micro digger in any enclosed space. the exhaust fumes would poison you. they also are only micro size cos they were designed to drive thru a house door, and on to the back garden for access reasons, you still need about 3m of height to actually use one. they are also a waste of time & money because unless you have a lot of digging experience, your workrate would be slower than using a spade.
2. buy a mattockhttp://t2.gstatic.com/images?q=tbn:A...9NKQ-yxWNk2Zq5 if i had a lad on the barrows (2 x) i would be looking at shifting 10-15t of clay using a mattock & a spade in a day shift. it is approx 2t :1m3, so you will easily get 2 or 3 skips out of it.
3. dig some test holes first to see how deep the back wall footings(foundation) actually are, you need to know what depth below ground the top & bottom of the concrete are just to be safe.
4. i spent from 1999 until 2009 on groundworks before being transferred into our transport dept. i have been dealing with structural engineers & building inspectors for a very long time, you really can't just start digging & hope for the best, if you alter the structure of the house without regs approval, it will invalidate house insurance and could land you in court. the original footings might need underpinning to strengthen them. this costs a heap of money.
5. people have had whole houses collapse by them digging the cellar out, those original concrete footings when first put in, would have been put in as high up as possible with the minimum height of blockwork walling above simply because walls cost a lot more than footings & all houses are built on a tight budget.
6. just give building control a ring & have a chat with an inspector to see what they think, don't mention the neighbour already doing it though.
7. i'm not trying to put a stop to you doing this.. 3 years ago we ended up helping out a bloke who had wanted to build an underground L shaped garage & employed some cowboys. the advice he'd been given meant he spent £20k on something useless & not what he wanted. there was an rsj so big, he couldn't actually get his car in.... when we told him that everything he'd originally wanted was both doable & actually easier than what he got, he cried, but we had to make the best of what he'd got cos he'd blown £20k already.
From what I gather/know Mr Mowgli is very time served at what hes does Lee so Id take his advice as oppose most other offered on this subject lol lol
(not saying your not taking, just reiterating like)
Hello that such partner L33 LEG such that such corsamálaga'm from Spain and I have a mk II nova 1.2s,I wondered one thing about your nova mk II of the black color is this, how to follow the second reversing light right?, I mean the Spanish to be exact.
Is that I want to do the project that you have about the lights, but what happens is that I do not get any light to my country your not you know.I asked several times on ebay, but I'm still unanswered and much less in my power, you can explain me why?.Well if you do not understand some of what I'm writing, with only what you tell me I rewrite it, is that I am communicating with you THROUGH google translator and I write in English so badly.
Hey also say that your opel nova mk II ah I liked everything you've done, and all a happy new year greetings and ;)
you are doing well. no point rushing headlong into this sort of thing, your method so far looks pretty good,
Getting there boss.
What you need is a couple of 12 cubic yard skips IMO. I pay £100 for these but thats a cash price, dont know what the proper going rate is though?
time to go looking for a friendly farmer with a hole that needs filling in.....
Unless its good qaulity top soil not many will want it unfortunatly.
just tell them you are getting an austrian lodger.....
i still think you should do a test hole near the back & side walls just to see what the height of brickwork is. you may not need any retaining walls. cos the above pic looks a lot like made up ground to me, and not the original soil at all.
you will need to make a shallow, wide footing for the wall, you may want to lay them flat way on for strength. compact the soil back in, then if you want to make a workbench, you could lay concrete about 4" thick on over the soil (on polythene), fit a timber on to the top of the wall, and leave it in there, and make sure you use strong concrete with poly fibres in it. it will last forever. pm me your email addy & i'll supply plan pics if you want.
the big trick to laying blocks for strength is mix the mortar 4:1 & fairly stiff, then actually bed the blocks on using a lump hammer to a string & keep spirit levelling.
honestly, i think you are in the wrong line of work, you have a real aptitude for this...
****ing lol at the drive just full of dirt.
Wall going right up or just high enough to retain the earth?
Sounds good, Crack on lol
mental visualisation is one of the most important things to have in a building job like this... a lot of people do not possess it...Quote:
Originally Posted by L33 LEG
