Colin what rack are you running? is it a standard nova one extended?
I am a tard, by rack I obviously meant column. You know those 2 things that are basically the same after all lol
I can send you the whole column to work from, assuming the price is realistic.
Not sure what you mean by requirements/uses? My layman response is that I require it to operate the steering rack in response to inputs from the steering wheel, and it will be used in a race car..........but I'm sure you know this!
I wasn't sure exactly what bits you needed making up, our lathe at work isn't 110% down to the tiniest measurable amount accurate... but I could get bits made up to be if needed. I assume you were talking more generally than specifically the column lol
TBH it won't be something the boss will entertain as a job, so price will be very realistic if it's a bung me some cash for doing it on a sunday thing lol
Bits I'm in need of that require a lathe currently are;
The rods for the steering column and the bushes to support the inner column
Also needing some nylon 'top hat' bushes to support the gear linkage road where it goes through the bulkhead
And I'm considering sleeeving down the inner TCA bushes and the rear beam bushes to allow me to use an M8 titanium bolt, so will need some sleeves machined
Should be doable in our lathe, it's accurate enough for a good interference fit. If you send me the bits or detailed measurements I'll see what I can do.
This project's getting complicated now MK is involved, he's the most grunge scientist EVER lol
