Nice one mate, really does look great and I totally agree about building engines that aren't covered in 5hit !
i could be interested but they are only £500 new ;)Quote:
Originally Posted by chrisnovaturbo
dave thanks very much for the data :thumb:
From what i can understand, the vxr rods will fit the xe crank so i think i will be going the standard rod route for me :thumb:
what gear box were you planing on running ???
you just sticking to na now ??? :confused:
NA?? no mate i'm using a upgraded T25 (very similar spec to the gt25r - i can supply full spec if your interested) and if the rods and pistons from the vxr fit with little hassle i will be using them also, as for the box i was thinking f20 as its the simplest box to fit that can handle the most torque - i don't know how the f15 would cope and its a bit of a grey area in that most peoples opinion is just try it and see how long it takes for you to funk it (although i would ideally love a small block sccr but i can't justify spending the ££ atm) what box are you using?Quote:
f20 will cope fine
Why would you want an SCCR box on a turbocharged car? Unless youre buying new with custom ratios?
oh i need to read things properley lol i spoke to auto vaux today the pistons are £220 plus the vat mate :cool: if i cant find a strong small block box i will use an f28 it has been done before iirc :confused: when are you planning on collecting and building your engine ?Quote:
why wouldnt you want to ??? :thumb:Quote:
Originally Posted by alistairolsen
Unless your on a big turbo a sccr would actually be useless.
Most sccr kits have a tiny drop off in revs and on a small turbo that will mean your always out of the powerband, the same could be said for a NA engine too IMO.
There great on engines with a peaky powerband though wether it be FI or NA
Originally Posted by Jonlem
Apart from the obvious loss in top end speed, the f20 sccr box worked well on shaun larnders old yellow nova. Was certainly a little quicker up to say 80/90 than mine on f28.
You have to remember there are LOADS of ratios available for that box, I would personally like to see 2 identical nova lets, one with a F28 and one with a sccr to prove which is better as from what I have seen they do not suit the powerband a KKK gives a let engine, fair enough if its on a bigger turbo though but I think the gearing on a F28 is just about spot on for a let.
