No
John, i used a normal two piece 16v gasket, which i now realise was an uber fail lol
Ive not looked closely as i cba, but i think the sandwich plate o-ring is leaking too, i re-used the old one as it looked in ok condition.
No
personally, an oil pressure guage is handy, but on track you want a high pressure switch and a big light. Nothing subtle, a big **** off red lamp in your field of visionQuote:
I did that on my astra, leaked like a biatch :( Sump was ok though, use an 8v calibra bonded one, the way forward:thumb:Quote:
Originally Posted by Adam
Going see if i can get the gauges sitting better, if not i'll just remove them as i do have a set of 6dial clocks....
And aye the std oil pressure switch is a bit useless, it comes on at about 5psi, and with 5psi oil pressure your engine wont be running for long. lol
Rich-Yup, looks like thats what i'll have to do asap.
like mine you mean ?
http://img.photobucket.com/albums/v6...741resized.jpg
My oil lighte is better at lighting the interea than the standard light.
Also alot easyer to fit the gauges's to a mrk2 dash.
http://img.photobucket.com/albums/v6...ject/005-4.jpg
Yeah, i'll fit a light the size of that one :cool:
very early spec trailer side light wired to the oil light on the dash for FTW
It lights up the hole car when its on.
WTF?? Bit harsh Olly.Quote:
Understand what you are getting at - but zero workmanship levels? What a rediculous and unfounded comment?!
Cracked on with the exhaust earlier, got the flexi piece welded to the system, and then clamped to the exhaust manifold. All fits fine.
But being a cheap Sportex system the fitment isnt the best, so im going to have to have a play with the middle section/backbox to try and get it sitting better as its going to tap on the transmission tunnel under hard cornering.
http://img.photobucket.com/albums/v8...P/DSCN1440.jpg
Not an amazing weld, but its fine. :)
http://img.photobucket.com/albums/v8...P/DSCN1439.jpg
work·man·ship (wûrk-mun-ship)Quote:
Originally Posted by Will F
1. The skill of a craftsperson or artisan.
2. The quality of something made, as by an artisan:
3. Something made or produced by a workman.
4. The product of effort or endeavor.
workmanship Noun
the degree of skill with which an object is made
Meaning that I struggle to see how once it's done, Adam can be happy with how it looks, after he's put the effort in wiring them up, it wouldn't have took much for get them looking half decent... without the need of filler, fibreglass, smoothing etc.
~back on topic~
