^That is what I was going to say.
Id just tap it the next size up (10mm?) an change the allen fitting that goes through the antivibe mount.
No can do mike, Due to the way the bolts are, Check the pic, They serve two purposes.
Oh I see now, I assumed (from the pic of the bolt) the larger hex head is removable from the actual allen bolt ~ like a spacer type affair. Helicoil it is then.
That method gets my vote too - nice work btw :thumb:Quote:
Originally Posted by peester
Works i had to do it on mine for MOT.Quote:
Originally Posted by Iain
Good work.
Glad you got your steering sorted, that test drive on the private testing grounds is getting evermore closer now!!
I think there is a slight drip from the banjo in that pic you've posted!!! :p lol
Good work dude
Nice work. I 3rd the brake pipe answer, it will "point" the other way once you spin it around.
Sorted the brake line out, not sure if it was the twisting or the other tweaking I did to it but it's clearing everything now:
http://iainel.co.uk/images/forums/NovaWIP2a/304.JPG
Also got my fusebox mounted in the dash, all wiring is finished so getting the dash ready for mounting:
http://iainel.co.uk/images/forums/NovaWIP2a/305.JPG
