standard crank - same as me
steel rods - same as me (i assume the crank is different in the corsa vxr so the vxr rods would not fit the 16xe crank??)
corsa vxr pistons (with machined inserts because the gudgen pin is bigger) - are these cheaper/easier to use that omega style pistons? what reason are you using the vxr pistons over standard? lower comp ratio?
head studs - arp?
cometic gasket - same as me
standard head - same as me
standard cams - same as me
corsa vxr turbo - i'm not sure if the spacings on the head ports are the same across both engines? but i'm using a custom tubular manifold and a upgraded T25 for cost reasons.
manzle powerbox inlet - i'm going to go custom here too.
Not sure what variety of management i'm going to use yet?
