shocked they weight the same, most bits look noticeably bigger on the f10
can you lighten the casing at all by drilling holes in the bell housing part or removing webbing etc?
with the amount of power going thru it, i'd say leave the gbox castings well alone.
Have you thought about finding a lighter engine?
The corsa 1.0 I3 12v is all alumininium and must weigh a good 20-30kg's less than your current one.
granted you've just invested in your current engine but I would look at this engine rather than a x14xe devived one in future
you'll have problems with getting suitable parts but It would be worth it to not be lumped with the cast iron block and 2 valves per cylinder.
in PPC this month, theres a dyhatsui charade with a 1.0 3 cylinder turbo making 250bhp
erm no.... cos its half composite
you can insult me all you like, but i was only answered your suggestion.. which would look good on an all steel car (look up jimmy shines bare nekid pickup truck) but colins car has not got much outer steel left, apart from the roof.
