Exactly that... how all the adjustment is designed on simps, doesn't even have to be a lot of work if you do it right.Quote:
Originally Posted by burgo
Ste is saying he can't work with original dimensions etc though, as it will all be slightly out.
ste, paypal for moneez for a ride please cheif!
have you ever done four wheel alignment on a car? takes at least an hour and then the adjust-ability can still slip.Quote:
Originally Posted by SR-Rally
each of the plates would be stamped as to what geometry it gives then is a simple case of swapping them which could be made easy and quick if designed right
no I never have.Quote:
I see what you mean, just alot of work to begin with but after that should be pretty straight forward to set up / adjust :thumb:Quote:
It's not, because you don't measure all the plates, just calculate it, start off with a set size, measure the geometry, rest can be worked out from the lengths of struts etc.Quote:
Top weldage!!!
i see what your saying guys but basicly all it will end up in is an adjustable top mount again will it not? difference is to set it up instead of moving it where you want it and locking it off you would have to check it dismantle half the suspension and reasemble and check again ect seems like a pain in the **** in comparison to using these top mounts
pluss fixed mounts are ideal if you can guarentee both sides are exactly symetrical to within half a mm and i cant so to identical plates could give different geometry from side to side even though the plates are exact. hense again the beuty of these you dont set them up so there in the same positions you adjust them untill your geometry is perfect compensates for any design intollerences so to speak
again like i say please dont forget although they look new ect the legs are designed to be in the same places and are only as exact as what the rotten legs were! like i say i know its not the best way to correct it but they are the easiest way on this project to ensure its geometry is bang on and can compensate each wheel individualy for and screw up on the fabbing side of things
the type im looking at do exactly the same as what your talking about but can be adjusted ect as and when and can be adapted to lock using small roll pins once the geometry is set
i agree and if it was a precision designed chassis fabricated on the floor to amazing tollerances then i would defenatly prefer the idea of set plates but please dont be fooled my shell isnt at the end of it its still structured around a 20 year old spanish built nova!
lmao i would rep you southie but it says i need to spread some around before giving it to you again lolQuote:
Originally Posted by Southie
Ste, i think those adjustable plates are perfect.
seen plenty of touring cars with those type.
and mk999 they will never shift an inch as the pressure is all pushing upwards and not sliding left to right if that makes sense.
keep up the great work ste.
Until your doing some serious cornering speeds...Quote:
Originally Posted by bmw156
Pretty sure the people teaching me know what they're on about tbh.Quote:
Resolution of forces says otherwise too, if you want it in black and white.
there will be alot of force acting on these mounts in all directions that is for sure but the point is are these forces going to be enough?
im going to try them any way as they apear to be the standard that all the d1 drift boys ect head towards and they dont report any major problems.
at worst say they do slip it means i got to move it back to where it was roughly and have it aligned again its not going to be the end of the world as im not going to use it every day as a shoping car
i like the input and i have taken on board your concerns guys but seriously i feel that this is going to be the easiest and best way to tackle the problem of alignment isues
and lets face it if over the whole project thats going to be my only concern im laughing dont you think
any dates yet ste?
finished the mounts the other week but just remembered i never posted the pics lol so this will bring you up to date
block in place as you can see if you look at the pic you can see the block is perfectly inline and level with the chassis legs
http://img.photobucket.com/albums/v6...g?t=1288877752
new f28 mount tacked up and in place
http://img.photobucket.com/albums/v6...g?t=1288877933
and thats up to date mounts done just got a staibaliser rod to sort out for the back of the head to the top of the bulk head to sort and thats the mounts done
the nova is now covered over and in the back of the workshop for a few weeks while i get my cav turbo rebuilt if anybody is interested though i will get pics up of the cav refresh as im doing it to keep the thread going
also its going to be abit slow in progress at the min as i have tendanitous in my had wrist and lower arm which is causing problems but we will soldier on lol
Yea get pics up of the cav ste be good to see it spudly will be suscribed because it a turbo lol.
spuds been in it 3 days after i brought it and he was creaming his pants thenQuote:
Originally Posted by damen
he also had a bee in his bonnet because i only payed 1200 quid for it and shes a minter lol
he needs to buy the one i found for 700 minus the let and f28.
You're at that stage Ste where I bet you spend just as much time standing back and admiring your work as you do doing the work! lol Keep it up!
Keep up the top work Ste :thumb:
great to see the engine in there :) wont be long till shes purring away
That is true but my cav thirst has been quenched a touch for now as youve seen my SRi yourself hehe:thumb:
top work :thumb:
looks sweet fella
first of how the nova currently sits and how it will be for the next 4-5 weeks
http://img.photobucket.com/albums/v6...g?t=1288900578
and todays start and progress on the cav
http://img.photobucket.com/albums/v6...g?t=1288900649
and the reason to get my backside in gear and get it striped and rebuilt
for those of you that dont know this is what happens when your head goes porus
so for all those that get a bee in your bonnet and run for the hills when you see orange water in your header tank and think your heads porus think again.
This is what you get when your heads porus
http://img.photobucket.com/albums/v6...g?t=1288900872
http://img.photobucket.com/albums/v6...g?t=1288900944
oh and a mystery hole i found in the gear box doesent mater as im changing the box as it crunches any way but never the less its interesting as i cant see why where or how the hell it was made
and thats where im at all ready to hit the floor when in the morning
somebody put mayo in that engine instead of coolant lol
Nova is looking good :) really cant wait for more progress :thumb:
that is probably the muckiest engine i've ever seen
Thats some nice goopy stuff there Ste, stop mincing about with the engine and get those horrid fecking wheels off, btw just to settle a discussion with Rob, what size are ya voodoo's?
that hole. ismnt it for reverse switch? and wow thats real full of mayo. how long was it run like that?
Originally Posted by nova_saloon
No iirc thats on the back of the box from this angle, that hole is into the bellhousing where the flywheel and clutch assembly are!
Nice! lol thank god Ive never had a head go that way, funny thing is i remember looking at mk2 fiestas when i was learning to drive, must have seen 20 or more with owners who had no idea why the oil was a bit more think and creamy/or the water being very oily lol..
As for the 4x4, is that engine mounted higher then standard? looks high in the last engine shot pic's.
yes mate it is slightly but thats because i have made my own mount from scratch rather than a kit all will be clear when it all gets final assembaly as to why all the mounts have been done the way they have but they are the way they are for a reason.
they could have all been normal mounts but its far easier to fab different mounts than it is to route awkward boost pipes and exhaust ect
thats mainly because the rocker cover gasket split a few days before it came of the roadQuote:
on an f28 mate the reverse switch is on top the box near the selector and the ident switch is underneath the hole has defenatly been smashed into it at some point but its odd as it looks like it was made from the inside out but by what i have no ideaQuote:
as for the mayo it was flushed only 5 days ago with a proper agent for cleaning the system after gasket failure then refilled with fresh coolent as i tryed the porus mod. 5 days later and sbout 50 miles and i got the coolant level light come on checked the header tank and it was solid with the stuff again so i think all i managed with the head and porus mod was to make it worse
what size would you like them to be whats it worth if i say 17s or 16s lol ?
i think this should be at least 23% now what you think guys ?
got abit more done also when i brought the cav the guy i got it of lived about 5 miles from AP racings develpment center and claimed that they had used the cav as a development car for a clutch kit for the f28/c20let and it had had about 4 clutches fitted and tryed on it free of charge
I just thought yeah yeah as you do but it apears he may well of been telling the truth.
The hole in the gearbox after we cleaned it all up was obvious that it wasnt a smashed hole but a cleanly drilled hole in just the right place to inspect the clutch
when we split the box from block low and behold theres an ap clutch and writen on the cover plate in marker pen was Revision 4 batch 1 prototest and on the other side a load of random letters and numbers part number?
same on the friction plate.
so it apears that it may have been ap that made the hole as f28 boxes dont have an inspection cover and the old bloke i got it of was telling the truth. Bonus
Any way some pics of todays progress
http://img.photobucket.com/albums/v6...g?t=1289004567
http://img.photobucket.com/albums/v6...g?t=1289004645
http://img.photobucket.com/albums/v6...g?t=1289004746
Looking good, I'd be inclined to bin those rubber mounts and fit something better which will mean altering the mounts as they use a single UNF threaded bolt.
Should be a cracking car if you finish it off with the right parts :)
Loving the Chassis
Bonus on the clutch Ste, but who wants shooting for the sump gasket
