I'm sure that used to say fuel level lol:pQuote:
Might paint inside and bay myself, not sure about the exterior.Quote:
nice work Ian, :)
Good work on the shell, you lined the catches up well after all then..lol
20 measurements each side and a couple of drawing attempts but should only be a couple of mm difference now. :cool:
Looks good dude, yeah might have edited it! lol
Good work!
coo, youve bought the bonnet ive had my eye on getting one soon too.. my ol' bonnet has a dent in it and the strengthened fibre-glass version (the one that goes onto o.e hinges) is just one ive fancied for a while..
do you have to use rally-esque pins/catches for it, cannot use o.e catch??
All the holes on the underneath are filled in (latch, rubber stops etc). I guess you could mod it to fit a latch but I don't think it was made with that in mind.
Aerocatches look quite cool anyway! Better than the classic pin design & lockable so safe.
Rubbish update, it's taking me ages to choose/buy/paint it so doing odd jobs instead.
Was cleaning the underside of my slam panel and noticed more weight saving that could be done! 262 grams of pure unrequired metal!
http://iainel.co.uk/images/forums/NovaWIP2/596.JPG
Gone:
http://iainel.co.uk/images/forums/NovaWIP2/597.JPG
Looks weird from the top without the spring bit!
http://iainel.co.uk/images/forums/NovaWIP2/598.JPG
Also drilled the rear bumper holes, guessed the measurements and they were bang on, winner!
http://iainel.co.uk/images/forums/NovaWIP2/599.JPG
That's some crazy weight saving.
Dear LordQuote:
Originally Posted by Lionel
Exciting stuff eh.
lmfao. that slam panel weight savage is legendary
I can see his next update, after a few beers and watching an episode of the simpsons.......
Looky, speed holes......
1722 grams saved from drilling holes in the entire shell, started here.....
Iain, why not just go for alloy replacement slam, or chopped out one for access?
Thats half a second shaved off your 1/4 time right there!!!
I never get that, you can get the rad out with a xe in piece of piss, so when does it need removing...Quote:
I did think about removing it a while ago, but decided it wasn't worth it. Would replace with alloy one if I did remove it though.
carbon fibre one ?
carbon fibre shell? space framed out with a 4wd beast?
Go on you know you want to
OK not much progress, but the cage is repainted matt black:
http://iainel.co.uk/images/forums/NovaWIP2/600.JPG
http://iainel.co.uk/images/forums/NovaWIP2/601.JPG
http://iainel.co.uk/images/forums/NovaWIP2/602.JPG
Suspension and steering gear has been loosely bolted/cable tied in place to make it a rolling shell again. First time off axle stands in about 6 months?!
http://iainel.co.uk/images/forums/NovaWIP2/603.JPG
http://iainel.co.uk/images/forums/NovaWIP2/604.JPG
http://iainel.co.uk/images/forums/NovaWIP2/605.JPG
http://iainel.co.uk/images/forums/NovaWIP2/606.JPG
Front wings have been seam sealered where they have been rolled:
http://iainel.co.uk/images/forums/NovaWIP2/607.JPG
And annoyingly I have somehow broken my toptint windscreen in storage! Grr.
http://iainel.co.uk/images/forums/NovaWIP2/608.JPG
Looks good Iain, early style boot will make a difference :)
It needs lowering lol
More info on the turbo brick needed. lol
Whitey is looking very impressive thought mate! colonhatsofftoyousir
Looking good dude, wouldn't it have been easier to paint the cage after the shells painted?
Guessing he's thinking along the lines that it's easier to mask up the cage than an entire shell?Quote:
Figured masking up a cage is easier than masking up a whole car when it's done! lol
Edit: Yep as above!
Masking a cage isnt easy!
monster truck novas FTW. all you got to do now is make the rear wheels turn with the front. haha
why not paint the cage the same colour as the shell? no masking...
Breaks it up a bit having black seats, wheel, cage etc I think. And I have black cage padding for it.
cages always have to be a different colour, it's just the rules lol
Going to get a quote for powdercoating loads of stuff so decided to strip them down ready. XE covers:
http://iainel.co.uk/images/forums/NovaWIP2/609.JPG
Rear beam is looking a bit tired, and I think the bottom shock mounts are knackered:
http://iainel.co.uk/images/forums/NovaWIP2/610.JPG
So I removed the ARB:
http://iainel.co.uk/images/forums/NovaWIP2/611.JPG
The replacement beam, have since removed the rear drums/mounts etc:
http://iainel.co.uk/images/forums/NovaWIP2/612.JPG
Rear axle bush cut off at one end:
http://iainel.co.uk/images/forums/NovaWIP2/613.JPG
And out:
http://iainel.co.uk/images/forums/NovaWIP2/614.JPG
Same with front lower arm:
http://iainel.co.uk/images/forums/NovaWIP2/615.JPG
And components ready for cleaning and powercoating/painting. Is it worth plating/strengthening the bottom of the lower arm?
http://iainel.co.uk/images/forums/NovaWIP2/616.JPG
Also picked up another F20 gearbox to fit my Quaife diff in to:
http://iainel.co.uk/images/forums/NovaWIP2/617.JPG
a lot of people say strengthening the lower arms is bad, as they bend if u crash and dont bend the chassis, howver mine are strenghtened as are quie a lot of peoples.
Glad to see youre having the lot powdercoated, be worthwhile with all your bling bling shiny bits!
Iain, have you considered fitting a Corsa rear ARB?
A ha ha ha ha ha lolQuote:
Originally Posted by iainel
Yeah noticed a lot of people have strengthened them. Got me thinking about it as they could flex quite a bit when I put them in the vice.
Corsa rear ARB, does that go inside the beam or is it different?
Different
IMO if you don't strengthen the underside of the front arms your asking for trouble, but then i don't know of anyone who wouldn't wen doing a good XE/LET conversion.
Also i like the bush removal, similar to how me and my mate did his lol
And as for Corsa anti roll bar, Humm you could try it, or go for a straight bar across the rear part of the rear beam, to them tow mount holes, Benn was going to try, don't know if he did or not.
All looking good though mate.
http://img.photobucket.com/albums/v1...a/DSC04753.jpg
Corsa whiteline rear ARB
The corsa one of over 15mm wider each side...
I'm waiting on a cav one comming to me to try and use, its ment to fit better.
So i will be soon.
I haven't plated my lower arms, after seeing how they are ment to fold when you slide in to a kerb. So i'd rather they fold them it bent the chassis.
