Where have you ordered all the brake lines & fittings from?
Thanks.
Thanks.
Most of it came through Think Auto mate
Thought as much. Thanks.
Have you used anything special for routing the lines out into the fr arches for the fr calipers? ie bulkhead fittings or whatever.
The whole car is using bulkhead fittings for fuel and brakes.
I haven't installed the front lines yet but I do have bulkhead fittings for those, just not sure if I'm going to bother using them yet as the engine is really in the way for me to get to where I wanted to install them
Where they expensive ? Wanna be doing mine over the next couple of weeks.Quote:
Originally Posted by Jonlem
The bill for the brake setup was ?165 exc bias lever.
I did get a load more fittings than it turned out I needed so I'm going to return those for a refund.
Most expensive bit to do by far is a oil cooler, -10 fittings and hose is pricey.
What you got left !?! Was going to do mine fairly cheap, like grommets through body work to save on connectors & leaks !
Absolutely awesome
Everthing that is left is really no use as its bulkhead fttings and 90 degree swept bends that i was going to use to plumb the fronts in.
I must have 30 spare -6 and -8 red/blue Aeroquip fittings left over which I need to send back for a refund !
Might have to seek your advice on the pipework for the brakes and fuel then mate :)
