Liking what youve done with the heater.
that matrix/blower is genius, well done for making it all work.
If I'm being honest I got the idea from Baxter's attempt, remember him saying he had issues mounting the blower tho. Hopefully with some nice ducting it'll clear the screen and use the centre vents for myself.
http://i11.photobucket.com/albums/a1...Picture007.jpg
Nice work Iain, although the heater idea wasn't yours I feel that you have executed the design alot better than your influence lol
I'll pop over to see you next week at some point :thumb:
mine only had to last for 2months thru winter, **** spending time on it lolQuote:
Originally Posted by nova ian
Looks like the plan with the heater worked well. Slim line fan needed tho.
dont blow enought, the matrix is that tight, it just ends up blowing back thru the fan and stalling itQuote:
Iain if your not using solid mounts you might want to cut more off the matrix pipe, or grind the nib off the inlet.
thats what i was thinkingQuote:
saying thats its comeing on very well .
Benn also benefit of using the standard one is I get to retain the standard switch and 3 speed settings :)
Scott/Kevster it's on TAS solid mounts, I think it has cleared enough not to cause problems - the pipe may touch the manifold but it shouldn't crush the pipe in to the matrix solid pipe. If it does look close I can undo the matrix bolts and pull it out slightly too :)
