Not yet :)
Not yet :)
In that case, good work. Keep on it.
LmaoQuote:
Originally Posted by Adam
Good work dude, lambda is just like mine!
Nice welding on the lambda boss.
http://iainel.co.uk/images/forums/NovaWIP2a/183.JPG
Hhhmm hide the loom, then run it along the slam panel? *shakes head*
this is coming allong well mate!!! doe's look tasty!!
Cheers all. Ben it's not there permanently, just while I fit and remove the radiator - hoped it was in for good until I found the manifold wouldn't fit with it in place!
As the car stands
http://iainel.co.uk/images/forums/NovaWIP2a/188.JPG
Painted up the manifold with Halfords 650C paint:
http://iainel.co.uk/images/forums/NovaWIP2a/189.JPG
And fitted. Although I've just removed and refitted it to get the radiator in, d'oh:
http://iainel.co.uk/images/forums/NovaWIP2a/190.JPG
Fuel hoses, one was way shorter than the other:
http://iainel.co.uk/images/forums/NovaWIP2a/191.JPG
So I extended it slightly so it reaches through the hole in the chassis:
http://iainel.co.uk/images/forums/NovaWIP2a/192.JPG
Also made up my two 8mm ID plastic hoses to run the length of the floorpan:
http://iainel.co.uk/images/forums/NovaWIP2a/193.JPG
8mm barbed ends with mikalor clamps:
http://iainel.co.uk/images/forums/NovaWIP2a/194.JPG
Will have some fuel system finished pics tomorrow as I just need to connect up one more hose and it's done.
Nice progress iain glad you sorted the manifold problem.
Very neat work dude.
