Horizontal is ok.
Anything as long as the probe doesnt point up (fitted underneath the manifold...) If you get me.
Horizontal is ok.
he was talking about snow tyres the other night FFS lolQuote:
Originally Posted by chimp007_uk
Think I've found somewhere suitable under the sump to fit a lambda bung so I'll get one ordered.
Trial fitted my strut brace as I thought I noticed a potential problem:
http://iainel.co.uk/images/forums/NovaWIP2a/164.JPG
Yep thats not too good:
http://iainel.co.uk/images/forums/NovaWIP2a/165.JPG
Whipped the pipe off and remade it with a banjo on one end, just need a banjo bolt:
http://iainel.co.uk/images/forums/NovaWIP2a/166.JPG
Engine loom is now connected to the fusebox, I need to lay my fuel pump wires and fit a relay to provide switched live feeds from the +ve:
http://iainel.co.uk/images/forums/NovaWIP2a/167.JPG
Connected up my oil pressure gauge wire on to the arrowed spade and the clocks smoked like mad and burnt out another trace lol Something's wrong, but what? It's just one wire from the pressure sensor on the engine to the clocks
http://iainel.co.uk/images/forums/NovaWIP2a/168.JPG
Sure mines plugged in there...
Started a help thread here like you suggested: http://www.pngclub.com/forum/showthread.php?p=1743093
Oh no wiring problems for you now :( not good at all.
Getting there Iain.
Annoying to see the classic white nova and dirty/rusty rain water marks still continues... Lol
Just made up a fuel line end as a test. Black platic/nylon fuel line, dipped in hot water at the end and pushed in a barbed 8mm brass 8mm-8mm connector, and fitted a hose clamp. Look okay to use as a fuel line?
http://iainel.co.uk/images/forums/NovaWIP2a/169.JPG
http://iainel.co.uk/images/forums/NovaWIP2a/170.JPG
No different to whats use by manufacturers with push on fittings. Ok I say.
Yes fine.
