The yellow stay housing is the only one avaliable new from vauxhall, I've got a spare 4 if anyone wants one lol.
Well folks, it's time for Phase 2.
With the Hybrid turbo, the boost keeps spikeing over 10psi, which causes the ECU to cut the fuel (safety feature)
So it's time to fit the EDS Phase 2 chips! I've just fitted the spark plugs and 3.5 bar FPR. But I couldnt get the ECU boards to seperate so i've left it with Steven Gault, he's also not been able to get the boards to seperate too but hopefully he'll figure out a way, others usually come apart quite easily!!
Once i've the ECU back, i'm doing the car's first oil change, then it's off to the rollers to properly set up the actuator and see what it makes.
Keith
Sound's a bit annoying about the ECU, but I'm sure it will be all OK, should be quite a beast!
Upgrades sound good, can't wait to see what it makes on the rollers. :thumb:
What you hoping for on the rollers keith?
I'll be happy if it makes the claimed 280bhp that phase 2 is supposed to give.
Seeing as everything is tip-top on your engine Keith, I really think it should easily make the quoted figs. It's not like you are beginning to tune a tired 100k motor. I look forward to hearing the outcome.
The two boards unclip from the plastic plug housing on the ecu case Keith.
Theres like two clips either side
I await the masses of smileys once you've got it setup and running :D
video required of your reaction when you first plant it, would me interesting lol
will be interesting to see how it compares to the genuine eds phase 2 which imo is the best software for the let.
await the results keith should be good
