only thing will be wider arches, the rest will maintain the nova shape. Mainly because I’m keeping the full tilt/slide sunroof, it has to retain some of its GSI heritage haha.
kenny is wanting to keep it as nova looking as possible on the outside.
[QUOTE=millworm;2316482]Bring it on! Thats the same kind of reactions i get with the xe mk1 fiesta I built
What a waste of a xe ��! Haha
No going back now, looking forward to seeing how these two go back together.
First trial fit of the shell over the floor, LOVE IT ALREADY!!
Again, big shout out to Kenny for his hard work and commitment to this build https://uploads.tapatalk-cdn.com/202...59c366101f.jpg
https://uploads.tapatalk-cdn.com/202...d9e57c5ce6.jpg
https://uploads.tapatalk-cdn.com/202...82aa0bb358.jpg
Brilliant!!:)
Front bumper and grille are going to need some imagination. Or is there scope to shift some bits backwards?
Radiator in the back?
bumper and grille should be ok,,ish, main issue is the inlet, it might need a bit of a makeover, thinking about ditching the air to air coolers and using a charge cooler with the core cooled by means on a small evaporator linked into the air con system. It would mean I could ditch a huge amount of weight and pipe work, meaning I only need a coolant radiator and condenser at the front, the standard GSI bumper and grille should supply enough cooling for that, these engines don’t run an oil cooler either so that’s less demand on space too.
still a hell of a lot of work but the base looks good
Big milestone there, fits surprisingly well
