45mpg
45mpg
I dont suppose anyone knows what the wires in the multi plug that joins the engine loom and car loom together are for? Im putting a 1.7td in my mk2 cav but struggle with wiring at the best of times.
If anyone knows what they are colour for colour it`d be a massive bonus.
They will be for the coolant temp sensors, theres 3 of them and then theres your rad and speed sensor (if you have one), stop solenoid etc etc
71 on a run to Manchester. lol
Talking of which, did you do the white ring mod to the nova i've just bought off you?
hello all,
ive just bought a 1.5td nova, which im planning on up'in the fuel and boost on.
now, i was just wondering, is it really worthwhile fitting the 1.7td engine and doing the same? can i use my nova's gearbox, or will i need the 1.7td box/flywheel/driveshafts/clutch etc? is everything a straight swap, as they pretty much the same engines aren't they?
thanks
IMO you might as well stick with the 1.5 if its a good runner
right - i have been told instead ov runnin the boost controller just cut the pipe and block both up and allows you to run just under 2bar ??
any thoughts ? not sure how this deisel lark works hehe
http://www.cemetery.eclipse.co.uk/ri...leedvalve3.jpg
dont use this just block both ends ov pipe up with a bolt inserted into the pipe ?
