CAD ;)lol to make air box setup
https://ep1.pinkbike.org/p4pb18852765/p4pb18852765.jpg
Tried the 17s on the front
https://ep1.pinkbike.org/p4pb18852764/p4pb18852764.jpg
That's some high tech shizzle right there!
Bit more progress with the CAD ;) Only issue is will need to change bonnet stay setup once again :tard:
https://ep1.pinkbike.org/p5pb18858383/p5pb18858383.jpg
https://ep1.pinkbike.org/p5pb18858384/p5pb18858384.jpg
Rear bumper out of the mould pretty pleased with how its turned out :d needs a bit of a trim/sand and need to workout best way to mount
https://ep1.pinkbike.org/p5pb18858382/p5pb18858382.jpg
Rear arches on as well think moulds need work to meet bumper better. Also managed to pick up some tyres to try 17s on :d
https://ep1.pinkbike.org/p5pb18858386/p5pb18858386.jpg
https://ep1.pinkbike.org/p5pb18858387/p5pb18858387.jpg
Skills!
Fuel setup all pretty much done. Will hopefully be able to get it running soon just a bit of wiring still to do
- For anyone wondering this is the K20 out of another project car, the K20 for this is still to be rebuilt
https://ep1.pinkbike.org/p5pb18863468/p5pb18863468.jpg
https://ep1.pinkbike.org/p5pb18863469/p5pb18863469.jpg
Rolled it outside to use the lift for a few minutes, arches definitely need a good bit more trimming
https://ep1.pinkbike.org/p5pb18868621/p5pb18868621.jpg
Good work, Looks a bit like a Renault 5 now at the back. I have build a cold air feed similar to that on mine, go take a look at my project. I lowered my rad and took the air from behind the grill.
Progress on the air intake setup just need to get some sort of rubber seal to use around the top where it meets the bonnet and work on where the 2 pieces come together
All the pipework and sensor setup is done for the air filter itself
https://ep1.pinkbike.org/p5pb19011308/p5pb19011308.jpg
https://ep1.pinkbike.org/p5pb19011305/p5pb19011305.jpg
https://ep1.pinkbike.org/p5pb19011300/p5pb19011300.jpg
Front and rear undertray progress too :d
https://ep1.pinkbike.org/p5pb19011299/p5pb19011299.jpg
https://ep1.pinkbike.org/p5pb19011301/p5pb19011301.jpg
Cold air intake looks great. Is fibreglass strong enough for the underside of a rally car?
