Under seal i would have though
Great update James, it's a while since I last looked in.
Rear braided lines under the boot floor look rather long, also be carefull what you use on the expanding foam, as I tried doing some door builds with the stuff years ago & they melted.
Thanks Craig i will be careful
http://i248.photobucket.com/albums/g...Rebuild047.jpg
Be aware that brake lines touching the car body is an MOT failiure
I didn't realise loctite was SO tuff? would of thought the studs will just undo with the nuts if you ever need to take a wheel off...Quote:
Looking good!:)
red threadlock/loctite generally needs to be heated if you even want to undo it with a spanner on the end, shouldn't think it will let go with a nut spinning off. lol
lol well i was thinking what if the heat generated from the brakes(drums/discs) slowly decays the threadlock.. suppose they dont get that hot! and i have really underestimated itlol cool..Quote:
Originally Posted by MK999
fair point actually they will get fairly hot at times, but if you think about the stud will be spun into it's thread on tightening too, so both nut and stud will be roughly as tight as each other if done properly, so the stud only needs a small amount of persuasion to sit in place
wishing you was here mate, wide nova FTW, it feels so much more planted, good update mate :)
re: threadlock
i have a stud kit on the front of the nova, it took a hell of a headache to get the buggers out but double nut and patience is all ya need :)
Its unlikely to see an MOT but point taken i may re adjust their length todayQuote:
