Looking well!
Looking well!
Good work dude, coming on fast.
The eyelets for the harnesses, they arnt just screwed in to a hole are they? As the floor plate metal isn't very thick...
Brake lines look great.
You get spreader plates with them as a kit mate, they go under the car floor, some have the nut welded to them too..Quote:
Looks good mate, as for the wiper blade i would use a AX/ZX arm and then use a 18-19" flat blade as there the best to use IMO as at any speed over 70-80mph normal ones on single wiper set up will lift off during the sweep..
Ah cool cool, i know you can buy just eyelets so...
2nd the AX arm, very straight. I think i still have one if you want it..
Get some pics Benn :) I mocked up the standard Nova wiper with the longer blade from the 306 rear arm and it looked spot on though, so might just keep that (at least it parks a little lower down).
Yeah in the tunnel there's a large spreaderplate welded across the whole area to beef it up, and then the proper spreaders with welded nuts underneath that, so should be safe enough
Engine loom in (ignore engine sitting wonky doing something else atm):
http://iainel.co.uk/images/forums/NovaWIP2a/124.JPG
Routed the loom back on itself and behind the inlet manifold:
http://iainel.co.uk/images/forums/NovaWIP2a/125.JPG
And through the old servo hole. Also extended the multiplug in to the car to connect to my car loom:
http://iainel.co.uk/images/forums/NovaWIP2a/126.JPG
On a quest to find some sort of dashboard, I decided to hack up a standard one to see how far off it was from fitting:
http://iainel.co.uk/images/forums/NovaWIP2a/127.JPG
Weight saving (also makes it easier to chop up):
http://iainel.co.uk/images/forums/NovaWIP2a/128.JPG
http://iainel.co.uk/images/forums/NovaWIP2a/129.JPG
Chopped the ends off, extended the hole for the column, and it fits:
http://iainel.co.uk/images/forums/NovaWIP2a/130.JPG
Issue is the dash is wonky (shows how much my column has moved):
http://iainel.co.uk/images/forums/NovaWIP2a/131.JPG
So I could leave it there (and have the revcounter right in front of me, which is a bonus) or I can shift this over and make up a new plastic bit to fill the gap:
http://iainel.co.uk/images/forums/NovaWIP2a/132.JPG
Hmmmmmmmmmmm.
sorry but, why has the column moved..? quick rack? mounts?
Sod it bin the dash, go for a custom binnacle like Dar's one, and a switch/fuels bord panel etc.
Corsa epasQuote:
Originally Posted by peester
ah see.. im not a fan of dar-like custom dashes all odd bits n bobs.. but thats me..
but also not sure how youll sort this one out..
maybe replacing some of that metal re-inforcment, but bent slightly might curve the dash a bit..?
