Looks good Iain, nice work :)
will be fine, remember the lack of steel in mikes van of doom, that was still attached JUST lolQuote:
Originally Posted by iainel
^good point. Only attached by about half in of metal work.
Bias valve mounted next to the handbrake and plumbed in to the rear line:
http://iainel.co.uk/images/forums/NovaWIP2a/120.JPG
And p-clipped out of the way of the harness and seat:
http://iainel.co.uk/images/forums/NovaWIP2a/121.JPG
Also p-clipped out of the way of my feet, managed to use two of the shifter bolts to avoid drilling unnecessary holes in the tunnel:
http://iainel.co.uk/images/forums/NovaWIP2a/122.JPG
Also tried a 306 rear wiper arm on for size and it's far too small, can someone measure their "proper" single wiper (Storm?) for me?
http://iainel.co.uk/images/forums/NovaWIP2a/123.JPG
the arm is 16 inches with a 20 inch blade works spot on :thumb:
Nice one, will try and find a 16" arm.
weldy weldy.... ill measure mine when i get back if you like - i just used the citroen arm shortened by a couple of inches - and a corsa blade (cause I had some new ones kicking about)Quote:
cars looking mint :thumb:
you can buy mine if you want £12 posted? for arm and blade
Will let you know if I don't see anything suitable on my next scrappy visit, cheers.
one thing i did notice is that the spring on the citroen arm would beat the **** out of a vauxhall one in an arm wrestle....
