Yes it does, i've seen some things like what, wish i could use something like that.
Will the two frame rails not weigh a ton?
Its why I decided to stick with using all the 200sx parts, there's so much development been done and readiness of cheap(ish) parts available.
The rails aren't that heavy really but they're stopping a the bulkhead anyway and from there will be smaller tube work. I've left them long so I can use them as a reference point for measurements.
Getting there....
http://img.photobucket.com/albums/v3...ps0fa3ef2f.jpg
Very very impressive I'm watching to get some tips etc for when I 4x4 my nova which will happen once I get the Audi engine ruining and driving, thumbs up
I warn you, its VERY frustrating. Constantly having to re-think and change plans slightly. The measuring, tweeking, measureing gets old quick too! Lol
i think I have the height where it needs to be now leaving me with good geometry. Just want to move it back a few inches now but need to find out how much I can adjust the tie bars to re-centre the wheels.
Mine will be a lot less work with only the rear end and maybe slight tunnel mods as I plan to keep the engine transverse, it's mightily impressive though what you've done so far can't wait to see it progress
Thank you
Wow loving what you've done so far. And ah at the rails, sounds like a good plan, everything in the bar can be done from the spaceframe then...
Not 100% sure what you're asking mate? The front suspension is mounted to the subframe except tie bar where it mounts into a bracket which is attached to the chassis or in my case the box. The subframe also bolts to the box. The engine mounts to the subframe NOT the box. So in moving the engine back the subframe moves back thus moving the wheels back. Maybe a few more pics will help...
http://img.photobucket.com/albums/v3...va/file-23.jpg
http://img.photobucket.com/albums/v3...va/file-24.jpg
http://img.photobucket.com/albums/v3...va/file-25.jpg
http://img.photobucket.com/albums/v3...va/file-27.jpg
Jesus some progress what the hell
seriously impressive though mate
