correct burgo,if its in a corsa id defo use the small block box as the 1.7 flywheels weigh a ton compared to the 1.5 ones,the 1.5s rev a lot quicker due to this:thumb:Quote:
Yes all very well and good but, what do you do about power goin through the clutch.. it will slip like made when you get it wound up!Quote:
Originally Posted by davidfox280585
and also will the F13 be able to take 170ft lbs + ??
I plan on machining a Td flywheel to suit the friction plate from an xe and running the f18 or f20 with the longer 5th with an uprated Xe clutch
Well i ran mine like this and no issues, i personally think the 1.7 is overrated compared to a good 1.5 use a good quality clutch is all you needQuote:
Originally Posted by balley77vaux
i have never killed a vauxhall box in my life, ever, the xe hasnt and all my corsas have never trashed one the tds are quick and i like them but there not supercars ffs
your just not trying then lolQuote:
I have killed loads of boxes in my rs turbos and my old citroen lasted 2 week before it shat itself, i have never changed my td boxes and i drove them hard, 6 1.7 engines i blew in my corsavan running the same gearbox and clutch and shaftsQuote:
come on, i even snapped a shaft on a std 406 TD lol
Vaux running gear is awesome, ive never snapped a shaft or done a box, ive done loads of clutches in even the nova xe hasnt died, only shaft i did was tigra cv due to me driving with a ripped boot and being lazy, my saxo had axles, shafts, box, mountings lower arms shocks just basicaly rubbishQuote:
What sort of fuel economy are you getting with these mods?
