Rubber lined P Clip's. Job done.
Or even rivet on saddle's.
Find a water hose the same bore and use that for the folding tabs cutting it open and sliding it over.
why not just get some of the standard screw on brake pipe clips that go onto the studs you're talking about? or is that me being stupid?
As others have already said Iain, rubber lined P-Clips is where it's at!!
and rivet them on, non of this pikey self tapper malarky!
Yeah thats what I was thinking of I think lol Some double plastic clip for holding them in place. Will hunt the scrappy for some!Quote:
Originally Posted by Prey
And I'll order some P-clips for use down the exhaust tunnel for the internal lines.
Cheers Simps I'll do that, will have to cut them down one side to fit them thuogh as they probably won't slide over the connectors :thumb:
Waxoyled inside my doors, rear quarters, chassis legs etc with 'clear' (yellow) waxoyl. Not sure if I did it right as it doesn't look all that great, but thinning it down by standing it in hot water really helped it's application (followed by using a brush to smooth it out after spraying it on)
http://iainel.co.uk/images/forums/NovaWIP2a/093.JPG
http://iainel.co.uk/images/forums/NovaWIP2a/094.JPG
More electrics in place:
http://iainel.co.uk/images/forums/NovaWIP2a/095.JPG
And we have power! Just wanted to check everything was working before cutting the loom to extend it to the front. All lights are working so good to start chopping and soldering...
http://iainel.co.uk/images/forums/NovaWIP2a/096.JPG
Looks good mate but get more Waxoil in there lol Get it so it's dripping out onto the floor (That's the way we do it at work, that's when you know you have enough)
It didn't drip :confused: Just went on and "stuck" in a matt/lumpy kinda way.
Aye I know what you mean...Maybe needs to be a bit thinner...?
Should protect it anyway though fella :)
Was out of a spray can so no way of adding thinners. The application of it wasn't anything like what I expected tbh (I may have done it wrong tho!)
