Great, thanks chaps.
Front wing cleerance won't be an issue on mine!
You will only need the arms Colin. Tie Rods will need to be suited to your cross member and brackets may as well be too.
I have a surplus pair of brackets and tie rods if for any reason you need them.
Mine are Ben's arms but the rest is all fabricated to suit my car. I run a lot of caster and my cross member isn't in the original position. Gearbox doesn't come near the tie bars on mine and yours is small block so should be loads of room.
I have an extra brace under my front end, that's the only thing you will struggle with for clearance.
Lovely.
Was lucky enough to see the car in person today :)
