well I was told to help the aged this week so I let you join in with your links later if you can manage to eat your dinner without spilling any on your bib ill give you a gold star lol :pQuote:
nice one, it'll add to my collection!
Cheers guys, sadly I literally have no more than maybe 6 inches to fit a silencer in there at best.
It may not even work anyway as the exhaust is very close to the tyre anyway and a silencer will mean its even closer.
Maybe I could go with something like the japs do with a 20 foot silencer pointing upwards, or something off a Scania truck ! lol
Sounds like a plan mate was Ben ok with knocking those bits upQuote:
Originally Posted by Jonlem
It sure does ! should blend in nicely with the subtle bodykit it has lol
Yes he is although he has just buggered his back up so I expect there is going to be a delay as he will quickly get behind with all his other jobs.
I'll call you once I have spoken to him though mate.
wow looks like its going to be impresive matey.
iain
Sounds good mate cheersQuote:
I hope so mate. Should be a good laugh. Cheers GarethQuote:
Originally Posted by NOV4_SPORT
Well I managed to get something done today even thought its not much.
I started refixing the rear brakes but then noticed I have been supplied the wrong disks.
http://i761.photobucket.com/albums/x...0/DSC03244.jpg
So I decided to mock fit the rear axle to make sure the coilover lines up for the new bracket.
http://i761.photobucket.com/albums/x...0/DSC03245.jpg
made the bracket to suit.
http://i761.photobucket.com/albums/x...0/DSC03246.jpg
welded it in place
http://i761.photobucket.com/albums/x...0/DSC03248.jpg
And everything was going so well until when we held the axle up in place the new bracket that bolts onto the strut base was too far inward :cry:
so out came the 3mm plate and made the template to suit (starwars comes to mind)
http://i761.photobucket.com/albums/x...0/DSC03250.jpg
http://i761.photobucket.com/albums/x...0/DSC03251.jpg
http://i761.photobucket.com/albums/x...0/DSC03252.jpg
I have put a single triangulation underneath but I think I may need another
http://i761.photobucket.com/albums/x...0/DSC03254.jpg
Ill get the other side finished tomorrow and start with other pressing things
Cheers Gareth
for the beam, you can just weld in a piece of box under your new plate, will be plenty strong enough, pretty much what i did on mine
Cheers Lee I might look into it at some point, but ill see how what I have done pans out :thumb:Quote:
Originally Posted by lee303
Managed to get the back axel finished in a fashion just go the barakes built then sorted really.
The finished article
http://i761.photobucket.com/albums/x...0/DSC03268.jpg
http://i761.photobucket.com/albums/x...0/DSC03266.jpg
Then I decided to carry out more demolition work by starting to cut the line for the dry sump kit
http://i761.photobucket.com/albums/x...0/DSC03270.jpg
Then I got a bit off topic by making the brackets to hold my fuel tank
http://i761.photobucket.com/albums/x...0/DSC03263.jpg
it will sit something like this
http://i761.photobucket.com/albums/x...0/DSC03262.jpg
I also tried to work out when everthing else was going to sit
http://i761.photobucket.com/albums/x...0/DSC03264.jpg
Cheers Gareth
Is it a better idea to have as much of the fuel system as far forward as possible in case of rear impact? Just thinking out loud...
Turrets and beam look awesome by the way
Cheers Iain I did think about that and im not sure thats where everything is going to stay :confused:Quote:
Originally Posted by Iain
You want to try getting your corner weights tested mate then work out where the best places are for the fuel parts.
I know that should be something I'll look intoQuote:
Looking good Gareth, personally I wouldn't fit the swirl pot there as it is as mentioned a bit of a hazard if things go wrong.
Cheers bud that was just to see where it looked good :thumb:Quote:
Well I didnt make much progress this weekend, as I was helping wwmnw to try and progress his.
Got the fibreglass bonnet painted
http://i761.photobucket.com/albums/x...0/DSC03317.jpg
Needs a polish really
http://i761.photobucket.com/albums/x...0/DSC03318.jpg
Thats all for now.
Cheers Gareth
Well got a little bit done yesterday. Managed to get the pedal box sat in place its no the best fitment but it should work
http://i761.photobucket.com/albums/x...0/DSC03346.jpg
Made a couple of plates to hide where the old braking system sat
http://i761.photobucket.com/albums/x...0/DSC03351.jpg
Also ran the front bake lines to the t-piece.
http://i761.photobucket.com/albums/x...0/DSC03345.jpg
Plates fitted
http://i761.photobucket.com/albums/x...0/DSC03352.jpg
I modded and welded in a plate in for the dry sump kit
http://i761.photobucket.com/albums/x...0/DSC03355.jpg
Not sure if im happy with the welds
http://i761.photobucket.com/albums/x...0/DSC03357.jpg
Then I ran out of welding gas so need to finish the inside welds.
Since I still had time I Started cutting and drilling the old seat mount to fit some new rails
And Finally polished the bonnet seems to have come up ok.
Thats all for now cheers
Got some moreweldinggas today and after the cinema I decided to finish the chassis leg
Finishedthewelds on the engine bay side
http://i761.photobucket.com/albums/x...0/DSC03383.jpg
http://i761.photobucket.com/albums/x...0/DSC03384.jpg
seam sealed both sides
http://i761.photobucket.com/albums/x...0/DSC03385.jpg
then shutz'd the inner arch to finish the job
http://i761.photobucket.com/albums/x...0/DSC03386.jpg
im detemind to get the seat rails done on fri and star putting it back together for the engine returning in time for pvs :thumb:
Cheers Gareth
Managed to get the rear brakes built up last night after I managed to get the correct fitting kit from vauxhall
Traill fitted the wheels on the rear, And i have realised that they are gonna be close
http://i761.photobucket.com/albums/x...0/DSC03389.jpg
Will hopefully get it nearly finished on the weekend :thumb:
Look good give a call satday all come help
Pro-race 3's? 7J width aren't they :(
Yes they are mate 45mm offsetQuote:
Originally Posted by Mazz
My 1.2's are the same :(
Shame they don't do them in a smaller width..
I know what you mean they are a bit excessiveQuote:
there the wheels im getting. never seen them on a nova till now lol
Glad to be of service lol :thumb:Quote:
Originally Posted by chrisnovaturbo
Rolled arch lips and spacers fine??
Why the clearance on the chassis leg?
On the front?Quote:
Because the pulleys for the oil pump for the pace kit fouls the chassis leg so I went a bit overkill to allow enough room :thumb:
yeah thats about right mateQuote:
Hows it coming mate? looks good so far..... when you aiming to get it to pod?
It's all good Im hoping to have it at pod for pvs will you be there :thumb:Quote:
Originally Posted by Mincyballs
Well another weekend gone and not much done but ill be out on it everynight during the week.
But I have got the rear turrets paiinted and finishe. Started remaving the brackets for the seat raisl to be put in. And i have sort of welded the exhaust together so when the manifold comes back I just have to flange the exhaust. I have also been told from steve (steveboyslim) that my engine should be ready to come back this weekend coming. :d
I will get some pics up over the week.
Cheers Gareth
Not putting it on the dyno then Gareth ?
In all honesty I would be if it was mine, will certainly work out cheaper than running it in then taking it to be mapped, plus you can fit it and use it from the off ;)
It is being ran in and mapped on the dyno but it'll just need the map alteratering a little once its fitted to the car.
David.
Touch the biggest fattest piece of wood I can that should be happening wedensday I think mate. :thumb:Quote:
OOH ! I bet Steves ar5ehole will be twitching on wednesday lol
Hope it goes well mate, I'm sure it will, its certainly the right way of doing things.
David, agreed but its nigh on ready to go with any leaks or potential problems sorted before installation which on a Nova is a huge benefit.
