looks fab :thumb:
looks fab :thumb:
Try daewoo sport blue :thumb: lolQuote:
Originally Posted by yoza
The progress should come thick and fast now i got that bit out the way :D
Rear legs !
This update was all done before the painting but forgot to put it on the thread !
From first inspection the rear arches were solid ! Little did i know someone had bodged in some plates in the arches. When i say bodged, i mean the plate was held only held by the sealer and what can only be discribed as bird s*it of weld. So, i started cutting out rot, lots and lots of rot ! When the rot was gone, i was left with these very big holes !
http://img1.putfile.com/thumb/3/8119003455.jpg
http://img1.putfile.com/thumb/3/8119003597.jpg
After i cut out the rot i got a grinder to it all, nice clean metal http://www.migweb.co.uk/forums/images/smilies/smile.gif
Scene as that part of the rear arch is double skined i had to use some real heavy duty metal. Heres a pic to show its width:
http://img1.putfile.com/thumb/3/8119003749.jpg
As you can see, it as thick as f*ck and will provide more than enuf strenght http://www.migweb.co.uk/forums/images/smilies/nod.gif
Anyway, heres the plates welded in. I still got to cut the bottom off and seam weld that edge. Got to put a couple of little plates elsewhere in the rear arches aswell.
http://img1.putfile.com/thumb/3/8119003683.jpg
http://img1.putfile.com/thumb/3/8119003561.jpg
Should get the underside of the car all stonechipped at the weekend, then i will be putting bits back on the shell !!!!!!!
__________________
I jus want to check im getting this right !?!
This is the rod from the cav gear selector setup. I have choped out 3 inches which was 1.5 inches either side of the bend, so i should just weld them together (nice and strait) then just straiten the end of the rod and thats it !?!
http://img1.putfile.com/thumb/3/8517413782.jpg
http://img1.putfile.com/thumb/3/8517413878.jpg
Couple of pics of my new SOLID bottom arms. I just cut the tops from my old arms and welded them to the bottom of the new ones http://www.migweb.co.uk/forums/image...es/biggrin.gif
http://img1.putfile.com/thumb/3/8517413828.jpg
Other things that got a quick lick of paint.
http://img1.putfile.com/thumb/3/8517413926.jpg
http://img1.putfile.com/thumb/3/8517413968.jpg
The first bit is back on the car :)
Its only the rack but its a a start.
Can anyone give me some tips on fitting the dash ? I didnt take the nova to bits and want to refit it all tomorrow. The heater box is be fitted ! Its a day day to rally car ;)
Got some more done to the nova on sat morning. Thought i would start with the wiring loom, now i didnt strip ther nova so i was worried about finding all the right places for everything, but the loom is SO simple it only took a couple of mins to find the rought layout.
Then it was a case of putting in the pedals, heater box, dash, etc etc.
I wanted to get the dash in in the moring so i could get this little beasty in:
http://img1.putfile.com/thumb/4/9010461793.jpg
Yep, all preped and ready for a coat of primer and paint.
What do you think of the colour ?
http://img1.putfile.com/thumb/4/9010461968.jpg
Anyway i ran out of time but heres a few pics of where im up to on the build. Note how tight the dash is to the cage !
http://img1.putfile.com/thumb/4/9010461940.jpg
http://img1.putfile.com/thumb/4/9010461984.jpg
http://img1.putfile.com/thumb/4/9010462012.jpg
Got a my lunch box painted as well as a couple of other bits (battery box !)
http://img1.putfile.com/thumb/4/9010461744.jpg
http://img1.putfile.com/thumb/4/9010461828.jpg
http://img1.putfile.com/thumb/4/9010461850.jpg
looking good mate! what cage is that?
really coming on fast matey, well done
Top stuff there, had to do quite a bit of welding,Lol.
Looking great mate!
