It is tempting. Not many people have 1000 bhp per tonne......
Stolen from wikipedia as I can't be arsed to type it out from my books but it gives you the general plus points!Quote:
Originally Posted by wikipedia
Small update......the engine is being put back together with a set of new pistons, along with shells, oil pump and Total Seal piston rings. The sump is also being modified to hold a bit more oil, as oil pressure seemed to be a problem with the higher level of cornering force that the car can now generate.
I don't have the money at this time to opt for a 'proper' engine build, so the plan is to run it with slightly less boost and/or revs, and hopefully it will last out this racing season, and allow me to fine tune the rest of the car.
Longer term I intend to get another engine built, using steel crank, steel rods and forged pistons. This may well take the form of a de-stroked 1300/1400 (possibly 16v), but I need to discuss this with experts to decide the best way forward and check out the likely costings.
Did your local parts chap give you any info on getting a 1.0L engine from brazil ?
I've drawn a complete blank on that one. They were very helpful, but tell me that GM Europe have no connection to GM Americas, so they can't access the database to even view the parts, let alone order them.
He gave me a contact name and number at a company called 'Vaux-Pro', who supply brand new crate engines to the Vauxhall Dealer Network, but when I spoke to them they were also unable to assist with sourcing stuff outside Europe.
So I think that option is out of the running, plus the more I think about it the more I think the engine block is unlikely be identical to a Nova (e.g. it might have lug mounts cast into it for a PAS pump).
Have you considered using this system to help your oil pressure issues
http://www.accusump.com/
I know a few rally boys who use it - Martin Bowyer (Bowyer Developments) has spec'ed it for the Engine for our Corsa S1600
Its basically a pressurised oil tank - that release's oil if the pressure drops
Might be worth looking into
Dave
I cant wait to see the next incarnation of this engine,
I love the development of this car, a short stroke 9500rpm screamer coming soon then?????
So glad your sticking with the 1.0 engine Colin,
The big block options would really have spoilt the car IMO,
Glad you can finish the season and hopefully get some good results from the car!
