lol get it done! and get it in to a body-shop.
freshly sorted bay rusting already lol
Definitely progressing too slow lol
nice one bud
Anti rust paint everywhere, woo
http://iainel.co.uk/images/forums/NovaWIP2/981.JPG
Getting any holes I need sorted before paint. Since my rollcage triangulation goes through the original wiring loom hole, I've decided to take some inspiration from Benn and Prey's latest wiring loom progress to run it here:
http://iainel.co.uk/images/forums/NovaWIP2/982.JPG
Handy hole from the side repeater I can use for the loom to enter the car:
http://iainel.co.uk/images/forums/NovaWIP2/983.JPG
Not as much as I had hoped but all the loom extension soldering should be inside the car:
http://iainel.co.uk/images/forums/NovaWIP2/984.JPG
Loom will enter the engine bay here, haven't got a side repeater to hand, but this should clear everything yes? It's pretty much in the middle of the slam where it meets the wing:
http://iainel.co.uk/images/forums/NovaWIP2/985.JPG
On second thoughts looking at these pics, once it's soldered up it won't be removable lol Any suggestions for this? Or just bigger holes and grommets?
tidy work, everything should miss it fine. if not then dont run any side reps. :)
Cheers Brucer, a very practical resolution; just remove anything that isn't gonna fit right!
Sorted this now. Just holesaw'd the loom holes to 38mm and going to order two headlamp grommets designed for a 'Triumph TR6/T120 (1962-70), TR7/T140 (1973-), BSA A65 (1971-72) and many other models'Quote:
Originally Posted by Myself
It might be making a lot of extra work but you could make it removeable using a twist fit connector, like what most vauxhalls have (looks like a round plug that pushes into another plug and then locks shut)
I was looking for all sorts of connectors and plugs that aren't too big and couldn't find any. Ordered myself those grommets, the 38mm hole I've now drilled is big enough to fit all the front plugs through so I can solder it up as one loom again.
Corsa B door loom connections ;)Quote:
Originally Posted by Adam
How many wires are on them? Got about 16 wires going to the front for headlights/rad etc.Quote:
Originally Posted by Mike
Today's progress, well chuffed as this is all I wanted to get done this weekend.
Jacked up and on some wheels and tyres, couldn't get it all the way over as my parents weren't about to help me do so:
http://iainel.co.uk/images/forums/NovaWIP2/986.JPG
Shot some primer on the floorpan:
http://iainel.co.uk/images/forums/NovaWIP2/987.JPG
On with two layers of 2pack Glacier White:
http://iainel.co.uk/images/forums/NovaWIP2/988.JPG
Mmm nice OE looking finish:
http://iainel.co.uk/images/forums/NovaWIP2/989.JPG
Same again on the boot floor:
http://iainel.co.uk/images/forums/NovaWIP2/990.JPG
All done, the last time anyone will ever see it lol:
http://iainel.co.uk/images/forums/NovaWIP2/991.JPG
Very nice mate, you've done well there :)
