Make sure any bolts you replace with stainless are up to the job. Stainless bolts/nuts are usually quite brittle
Dude, wire wheel on your grinder. SO much quicker and effective!
Looking good :)
Thats what i've been using today, the arch is mostly done now. Will start the other side tomoz.
Yeah i allways check the strengh of the bolts when i replace them.Quote:
Originally Posted by Adam
I have a huge (its 4foot tall) tube of high strengh bolts that have a nickle like silvery finish on them too, that are all 8.8 and above. Came from my dads work from the submarine bit when they moved.. Think i send you bottom pully bolts from that lot..
Spent the last two nights in the wheels arches stripping off all the paint and under seal, to re seal and then paint them properly. Which is eating up alot of time, but i killed the wire bush so that out of the window for the mo.
So i've refitted the std shochs and bits so shes a roller again, and welded over the old wiring loom hole and made a new one. And make the holes a bit better for where they enter the bulk head.
Where the old hole was. Could be seen in the bay.
http://img.photobucket.com/albums/v3...smoothing4.jpg
http://img.photobucket.com/albums/v3...smoothing5.jpg
Also cleaned up and enlarged the hole for the water pipe so this can have a proper gromit in it. You can see the new hole for where the wiring will enter the bay too, right up under the slam pannel.
http://img.photobucket.com/albums/v3...smoothing7.jpg
Game its a skim of fiberglass.
http://img.photobucket.com/albums/v3...smoothing6.jpg
Now for bed...lol
Good progress.
Going back - I plan to redo it all due to the underseal has started to come away.
Right the bays all finished now that this is done. The wiring comes in above the headlight, the feed wires drop down to it now, insted of around it where it could be seen..
http://img.photobucket.com/albums/v3...s/IMG_4660.jpg
Sadly been doing the very boring tack of cleaning all the wheel arches up for paint.
http://img.photobucket.com/albums/v3.../Archprep2.jpg
http://img.photobucket.com/albums/v3.../Archprep5.jpg
http://img.photobucket.com/albums/v3.../Archprep7.jpg
But here they are all clean, sadly hiding under the inch deep seam sealer i found the corner of the battrey tray/under the turret had got wet so had rusted so i've cut it out and replaced it.
http://img.photobucket.com/albums/v3.../Archprep6.jpg
Fixed. My weldings getting better but still not great on the thin stuff.
http://img.photobucket.com/albums/v3.../Archprep4.jpg
Eveythings been rusted with a rust killer/prohibater hence why its purple.
This is good to show how much seam sealer is sprayed over everything and how much is in the battrey tray/bulk head.
http://img.photobucket.com/albums/v3...s/Archprep.jpg
Just how Olly, theys been off and the stainless ones have been orderd ;)
http://img.photobucket.com/albums/v3...Archprep10.jpg
Gotta do the pass side tomoz, then its all ready to go to the body shop.
Good work cleaning the inner arches up. Going look sweet when all repainted :cool:
Its a long long hatefull job. But i hope they do.
Where is that close up pic from? cant quite make it out?
Getting there mate, lol underseal is ****e!
Its the tie bar bolts, so they arnt painted in, theyve been lossen and will be replaced after.
Cheers scott.
i have this problem i feel the need to polish everything on my sr lolQuote:
Do it.
lol i ment of the hole dude!Quote:
Ah ok then its from cross member..
Right another boring up date.
Got all the n/s arch all cleaned up, also there was more surface rust hiding under the sealer and paint there was no holes.
http://img.photobucket.com/albums/v3.../passarch2.jpg
http://img.photobucket.com/albums/v3.../passarch3.jpg
http://img.photobucket.com/albums/v3...s/passarch.jpg
looking awsome benn, maybe you should change your name to cpt shiney?;)
lol maybe.
I think you should bare metal polish the inner arches lol
See you say that.. I was sitting there coverd in crap thinking the metal comes up nice, wonder what it would polish like... lol
don't you dare! you spend far too much time cleaning it as it is!!
lol Cars need to be clean, i dont like driving my work van when its dirty..lol
Cant belive that rust mate! :( Did'nt ever exspect to see rust on your car tbh
awsome benn , the long boring jobs always give more satisfaction when ther done though :thumb:
Thats seamsealer for you, its good and bad, can keep rust at bay and can allso hide it and help it grow.Quote:
Originally Posted by ~~joycey~~
Yeah hopefully will look all nice when its bodycolour in the arches. Cheers dude.Quote:
Originally Posted by Riggy
Christ what a weekend.
So have been thinking about engines and havent been able to make mine mine up, do i use my xe as its a sweet running and quiet as a mouse, find a 1.8 8v and twin carb it up, find a let..
When i get sent a ebay link for a let few days to go, sitting at 900. It sells then get relisted the next day due to time waisters, http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300292044141 So a sat here looking at the ad and thought why not txt him a cash offer and see what he says. So i did, he txted back and said yes... Win.
Wad, ready to be spent..
http://i22.photobucket.com/albums/b3...s/IMG_4679.jpg
http://i22.photobucket.com/albums/b3...s/IMG_4681.jpg
So off we set, had hardly any sleep, but the nice cold morning sorts that out..
http://i22.photobucket.com/albums/b3...s/IMG_4682.jpg
I found that not even 30miles up the road and they still have deep snow, was so unfair!
http://i22.photobucket.com/albums/b3...s/IMG_7080.jpg
Anyway lots of driving later we pasted the Vauxhall plant in Luton, we end up in a small town called Olney to view this let.
http://i22.photobucket.com/albums/b3...s/IMG_7085.jpg
After following matey to his garage and watching him get stuck inthe snow, then sit with the engine on the limiter trying to get out of it.
He shows us the serecty to stop anyone getting in the garage.. Silver one drags the gold one out of way with seat belt..
http://i22.photobucket.com/albums/b3...s/IMG_7089.jpg
http://i22.photobucket.com/albums/b3...s/IMG_7090.jpg
Benn looking at said let,
http://i22.photobucket.com/albums/b3...s/IMG_7092.jpg
A very full garage.
http://i22.photobucket.com/albums/b3...s/IMG_7091.jpg
Did all the checks you guys said, big thanks for that! Finding them all ok i handed over 700 and started loading the car.
http://i22.photobucket.com/albums/b3...s/IMG_4687.jpg
On the way up the radio didnt have much on it, so my dad read to me, which i have to say was nice, and then all the way home too..
Read me this...
http://i22.photobucket.com/albums/b3...s/IMG_4714.jpg
My dad/ co-poilet/ story reader..lol Thank you, you're a legend as allways.
http://i22.photobucket.com/albums/b3...s/IMG_7097.jpg
Nice snow coverd back grounds from the M1..
http://i22.photobucket.com/albums/b3...s/IMG_4690.jpg
When we stoped for lunch,
http://i22.photobucket.com/albums/b3...s/IMG_4694.jpg
Bought me a whimpey! God i love their bugers! Time we stoped at, then saw the mk3 cav owners club....
http://i22.photobucket.com/albums/b3...s/IMG_7096.jpg
Finely home at. With a slammed vectra...
http://i22.photobucket.com/albums/b3...s/IMG_7098.jpg
Back at home.
http://i22.photobucket.com/albums/b3...s/IMG_4696.jpg
After doing a nice trip of.
http://i22.photobucket.com/albums/b3...s/IMG_4695.jpg
With a boot full of...
http://i22.photobucket.com/albums/b3...s/IMG_4697.jpg
http://i22.photobucket.com/albums/b3...s/IMG_4698.jpg
http://i22.photobucket.com/albums/b3...s/IMG_4712.jpg
Sc legendray hoist.
http://i22.photobucket.com/albums/b3...s/IMG_4699.jpg
New luk clutch that will go up for sale..
http://i22.photobucket.com/albums/b3...s/IMG_4700.jpg
Eeewww i dont think so.
http://i22.photobucket.com/albums/b3...s/IMG_4701.jpg
The blower..
http://i22.photobucket.com/albums/b3...s/IMG_4702.jpg
Should it have a the slight bend? Check that it moves, does but is stiff, is that good or bad?
http://i22.photobucket.com/albums/b3...s/IMG_4703.jpg
What should be on this?
http://i22.photobucket.com/albums/b3...s/IMG_4710.jpg
Can you get new ones of these? As they've seen better days.
http://i22.photobucket.com/albums/b3...s/IMG_4711.jpg
Sooooooooooo now i just need to get a few bits and do some stripping, sanding, painting, polishing then i can fit it...
Whats the easiest less cutting fmic i can use behind a uncut gsi front bumper?
Gen me up.
looks like you got a good buy there benn, did it not come with the f28??
well at least now you wont have to make too many mods to the beast:thumb:
and you dont have to go woooooshtiiissssss every time you change gearlol:D
edit durrrrrr just seen the vectra boot picslol.
no that actuator isnt supposed to be bent,and it looks like your gonna need a new water feed pipe to the turbo aswell. is that wire which has been bodged the lamda sensor??? if so i have a spanking new one here for you if you want it??? ims ure we could do a deal lol
oh and if you want any pics or need a look on my let i'll pop over and you can have a mooch
Wow, excellent stuff benn! Rich has an intercooler and some very nice pipework for sale too, might be worth pming him. Hmmm, i will but a let oneday!
Pauls told me the actuator rod should be ok.. the two pipes will be replaced while getting hidden.
No f28 ed, space f20 to be sold tho..lol
The lambda will be replaced too.
I want a ic that will fit behind the gsi bumper john, with the less cutted poss...
have a look at rich's for sale threads, iirc he used a frontera intercooler, that fits quite nicely, he did have to trim his front panel a bit though.Quote:
You gonna run it on the f20 or f28?
Top work Benn!
A nice Let will finish your car perfectly :cool:
Good price too.
Will look forward to clean up pics, and fitting!!! :)
You'll struggle hiding the fmic, unless you go for a small diesel one or something.
Or do some mods to the crossmember panel
Some pics or rich's for you benn.
http://i6.photobucket.com/albums/y22...DSC00054-2.jpg
http://i6.photobucket.com/albums/y22...DSC00029-3.jpg
Can't seem to find any pics of his intercooler though, must have sold it?
Ive seem them, but i dont want the ic on front. I dont want to cut my gsi anywhere that will show.
I dont mind cutting the front pannel, and will run the f20.Quote:
Originally Posted by John H
As said cross member i dont mind, but dont wanna cut my bumper.Quote:
Cheers too dude. Will really dive in when the cars at the bodyshop. So i can work in the garage with it and so on. Still just worried it might be a smokie crapper but.
just out of intrest whats the best way to polish things?
as i want my rocker cover etc done?
