is it still to late to buy an equal length shaft buddy ???
how much 4 just the short sharft thanks
I might be able to sort out another 2 short shafts out for you's
£75 posted if i can.
Cheers David.
money sat here waiting buddy
i dont mind if you going to do another set i just want a spare buddy as i already have one !
Tech question for those running the lay shaft on equal setup:-
What bolt thread / length is needed to mount the bracket to the block [it's two of them]
Any word on a delivery date David?
i spoke to him friday and he said they are awaiting heat treatment, i will contact him tomorrow to see how long they will be.
Cheers David.
did you order extra david ???
I used the same bolts as used on the alternator bottom bracket and engine to block mounts with the 15mm head.Quote:
Not much use if you are looking for pitch/length but just noticed no-one else has replied.
UPDATE;
Just to let you all know, I should have the driveshafts with me by monday evening so all being well you will have them with you some time next week.
Cheers David.
