probably your cheapest fix is to get your existing engine rebuilt, and lower the boost a tad.
The xtrac puma is a pretty good example of that, figures for the cost if xtrac charged labour etc on the bits they did is something mad like 1.5million iirc?Quote:
Probably true, but I was only putting 18psi through it, the problem is that the bottom end was standard, and just not able to cope with the boost/revs being thrown at it.Quote:
Originally Posted by mowgli
If I want to go forward and compete on level terms with the quick guys, it definitely needs forged pistons as a minimum, and preferably steel crank and rods too.
Sticking with the up to 1400 Class is still my preferred option, but it will all boil down to cost in the end.
I'm meeting with the Parts Manager at my local Vauxhall dealer tomorrow, I'm hoping he can find out more for me about the Brazilian 1.0 OHC engine to see if that is a realistic option.
colin i think you should rebuild your bottom end as is and then go for a 16v head. i know this mean a new or modifying the inlet and exhaust manifolds but the gains could be worth it
the car is still owned by chris it has xe in it now till his new engine built i think well it was running one at pvs. dave dixson has his old turbo and manifold for his novaQuote:
If you're going to stay as 1ltr turbo still, and go for a steel bottom end would it be worth while destroking a 1.3/1.4 rather than sleeveing a block so that it's a revvier lump?
And also having a bigger bore will give you more room for bigger valve area!
the 12ST has the lowest stroke of any stock gm engine. by going lower on the stroke, you would need a bespoke crank and still need forged pistons..
as the car was built using mini metro pistons, there is a really good probability that someone somewhere does forged pistons already for it, so they will cost less to obtain.
there are alread valve cutouts in the block that don't appear to affect the running
I think you should keep it within the 1.0L bracket - It's part of what makes this car unique.
Hold out for the brazilian lump then go to town on it.
I agree tbh, shame you cant write the rest of the season off then spend all year/winter soucring the parts and rebuilding.
The car is/was obviously very competitive in that class as it won it a few times iirc!
