Might be worth a ask in a vauxhall dealer to see the price/avalibilty and to compare to when you get a total price for one shipped over ???
Or someone that has a worldwide copy of EPC will be able to see if the blocks are the same :)
My copy only does vauxhall and Opel I think, but will check later
It's a good point Edd, thanks. I'm on friendly terms with the local main dealer Parts people, so I will nip in there and make the enquiry.Quote:
Originally Posted by Edd
I suppose there's also a chance that they might have access to a database with detailed photos of the block (EDIT ; which is precisely what you then went on to say in your second post!!).
Exciting times :)
Expensive timesQuote:
Cracking Car! Have you considered a carbon fibre gear shift similar to the WRC focus's carbon fibre handbrake. May save half a kilo at a guess although price/weight savings probably not worth it.
http://i298.photobucket.com/albums/m...24at164443.png
Bit of a long shot but this engine was not used in any of the "other marques" carrying gm engines eg daewoo, fiat etc? Might be a way of finding one in europe then.
nope it is brazil only.. they use corn ethanol. thats why its 12:1 cr.
12:1 turbo sounds tasty, chuck some petrol in it anyway lolQuote:
Originally Posted by mowgli
It's a good suggestion, I'd buy one if someone can make it at a sensible price. The aluminium one is actually quite heavy.Quote:
Originally Posted by OllieKing
