Originally Posted by
Paul
Put the earth on from the alternator to the engine, and that caused a problem. The car stopped turning off on the key. Had a play with it and thought that maybe it was the trickle wiring holding just enough voltage to keep the ECU on. Turned the engine on, took the key out and it was still running, took the batt. light bulb out to break the trickle wire and it turned off, So it was at fault. We put a diode in that up by the clocks and thats now sorted. (note to anyone running MBE, that this may happen)Paul
