Alloys look well on the sport edd
Does it use a cts? Could be that as its bad when cold...
Glad you sorted the other bits.
Looks great with the decals on Edd - Keep your head up. Your one fault away from an almost perfect car :)
Looks well that mate.well done.
Thanks for the positive comments everyone
I'm going to get new genuine CTS and stat to see if that sorts the idle out
Really running out of ideas now with this problem????
I have most of the parts to do the turbo conversion ready to fit, just need to sort the fcuking idle out ffsA dirty engine bay pic
http://i499.photobucket.com/albums/r...s/DSC_0016.jpg
Corsa servo fitted
Coil moved so I can fit oil filter relocation kit in its place
Bonnet cable and loom round inner wing
Dry cell battery under passenger seat
I'm not at all happy with the engine bay one bit tbh, waiting for a brand new GM gearbox and the turbo stuff to get it as I want
I don't know if this is your problem, but many moons ago after having an engine rebuild, I had an air pocket in the coolant system. Every time it got to temp it then got really cold-hot cold then hot cold etc.... It took me ages to finally get rid of the air block. It seemed fine and the coolant level was constant. Drove me mad!
I drained the whole lot out and refilled a measured liquid amount which I knew was roughly what it should have been, minus what was left in the engine. Ie all pipes and radiator were took off, replaced and refilled.
tidy car.....have you got a decal for the tailgate? Or have you not got round to fitting it yet?
I don't think I have a air lock, will double check when I change the thermostat
I do have a tailgate decal, when I get the roof and quarter painted I'm going to get my other tailgate painted and fit a different rear spoiler and put the decal on then
Just had a scroll through your thread here and what an absolute cracker! :thumb: Always think I'm looking at a hologram with those decals - looks the bizz fella, excellent job!
Best,
Tony
Cheers
Forgot to mention that the Corsa epas is working perfectly with the AK 15imp transducer
Full assistance when stationary, gradually reduces till minimal resistance at 40mph
Really happy with it
Any photos of what you did with the top get to the lock/barrel and bits right?
