Yep, arrow on the piston pointing towards the cams, lugs on the conrods pointing towards the flywheel. :)
Trying to stop dirt entering my block so fitted these. Fitted the gasket on the breather but does the sensor have anything?!
http://iainel.co.uk/images/forums/NovaWIP2/899.JPG
Temporarily fitted the waterpump and oil pump:
http://iainel.co.uk/images/forums/NovaWIP2/900.JPG
Slight modification so it clears the early belt cover nicely (you can see on the lug at the top) - also where the hell does the tab on the waterpump go? Can't find anything about it in Haynes!
http://iainel.co.uk/images/forums/NovaWIP2/901.JPG
Bottom end seals - anyone any ideas?
http://iainel.co.uk/images/forums/NovaWIP2/902.JPG
i would say the top left is the crank shaft to oil pump seal all the rest im not sure
oh yeah the engines looking smart mate
Cheers. Yeah I guessed the oil pump seal one, and I imagine the black rubber is for the oil pickup pipe. Dunno about the rest tho!
Left looks like the crank sensor seal?
Next in sump plug seal.
Put the cambelt back plate on before waterpump, theres a notch in it that the waterpump lines up with. Looks about right where it is now
Crank sensor is the one I've fitted on the front of the block?
Pretty sure the belt cover goes on after the pump as it hides one of the bolt heads. Also there's no marks on it to show where the pump sits. It's an early XE backplate if that makes a difference.Quote:
Originally Posted by Rich
Edit: This looks like a rundown of all bottom end gasket items:
1 x Sump Plug Washer (Bottom, second from left)
1 x Oil Pressure Relief Valve Washer (Bottom, right)
1 x Oil Pump Gasket
1 x Oil Pick Up Pipe o-ring (Bottom, second from right?)
1 x Crank Sensor o-ring (Bottom, left?)
1 x Crankshaft Oil Seal - Oil Pump End
1 x Crankshaft Oil Seal - Flywheel End
1 x Water Pump o-ring
1 x Dipstick Gasket
2 x Cork Sump Gaskets
One clean oil pump housing (thanks to Tom who I bought it off tbh, did a very nice job of cleaning it for me!):
http://iainel.co.uk/images/forums/NovaWIP2/903.JPG
Good condition gears:
http://iainel.co.uk/images/forums/NovaWIP2/904.JPG
Removed the relief valve from my old pump:
http://iainel.co.uk/images/forums/NovaWIP2/905.JPG
But it doesn't look in that good condition, some scratches on the outside - usable?
http://iainel.co.uk/images/forums/NovaWIP2/906.JPG
The crank sensor has a rubber o-ring on it
Edit-Ignore that, you already know
Engines looking fooking awesome btw!
