If you're worried about safety you got the wrong car, you have seen the door innards right? 1mm of land rover stopping power lol
christ iain, hardcore ****.
skills.
FAIL his name is IAN.Quote:
Originally Posted by peester
Nice work, keep it. Oh and fcuk the power steering off.
[quote=iainel]Collapsable is better for a head on crash to avoid the column being pushed towards you?quote]
Oooft, think of the damage:eek:, defo keep it collapsable!!
Yet he spells it Iain him self....:roll:Quote:
Originally Posted by Paul
wrongly spelt ian strikes again!
Hes a fool, its Ian, ask him :pQuote:
Spells it iain on msn too fool.
I think he spells it Iain, because Ian was already taken
lol It's Iain damnit, stop trying to wind me up.
Just been out and removed the head, all looks okay to me, although I've not had that much experience of engine internals tbh! No bent valves or anything though.
Good news then Ian :)
Good work Ian. :)
Nice one Ian :)
Yeah Iain.
Bodywork is taking shape, one side is almost complete!
Rear quarter pillars and sill are almost there:
http://iainel.co.uk/images/forums/NovaWIP2/408.JPG
Boot floor looking smooth (removed brackets and seatbelt holes):
http://iainel.co.uk/images/forums/NovaWIP2/409.JPG
Not too shabby delocking job:
http://iainel.co.uk/images/forums/NovaWIP2/410.JPG
Head off the block, here's some pics so anybody can tell me if there's any problems:
http://iainel.co.uk/images/forums/NovaWIP2/411.JPG
Bore:
http://iainel.co.uk/images/forums/NovaWIP2/412.JPG
Head:
http://iainel.co.uk/images/forums/NovaWIP2/413.JPG
http://iainel.co.uk/images/forums/NovaWIP2/414.JPG
Bar the cake in that bore it looks fine.
Head needs a proper degreasing/cleaning, looks like its not seen an oil change for a while.
Should be sound when rebuilt up tho! :)
Yeah going to buy myself one of those valve compressor tools and strip it down and clean it up properly.
yeah its to wide and big lolQuote:
Originally Posted by iainel
And makes 150hp and TORQUE out of the box :p
Removed drivers rear quarter today and got the arch tub in etch primer. Shedload of rust in this one so it's all cut out ready to replace. :mad:
Lip cut off:
http://iainel.co.uk/images/forums/NovaWIP2/415.JPG
Removal in pieces:
http://iainel.co.uk/images/forums/NovaWIP2/416.JPG
http://iainel.co.uk/images/forums/NovaWIP2/417.JPG
Rust :(
http://iainel.co.uk/images/forums/NovaWIP2/418.JPG
http://iainel.co.uk/images/forums/NovaWIP2/419.JPG
http://iainel.co.uk/images/forums/NovaWIP2/420.JPG
Removed:
http://iainel.co.uk/images/forums/NovaWIP2/421.JPG
http://iainel.co.uk/images/forums/NovaWIP2/422.JPG
Cleaned all the old underseal off, finished off some stitch welding and etch primered up (pic after first light coat):
http://iainel.co.uk/images/forums/NovaWIP2/423.JPG
Not so good!
But could of been worse..
Whats going on there at the bottom of the turret like bit? Is it a huge plate?
Not that bad, i've seen much much worse.
That rust on the inner arch behind the arch lip i assume?
At least its fixable :)
you have balls of steel lol good work buddy i just hope it come out hoq you wish !!!
Fair play for doing it all yourself. I was planning on doing mine but i pussied out on it lol
Other side looks a top job, as does the rest of your work :thumb:
Jesus - I've only ever done that much cutting when i know full well ill never have to put it back together again...
ouch. at least youve had plenty of practice with the welder now
Shame about the rot but at least you're going the right way about it.
Yeah it's a big plate Benn, I can't remember it needing to be that big but was done over a year ago now.
Yeah the rust is behind the arch lip in the splash guard/tub and on the bit that sits in the middle of the sill. TBH I'm not really phased by it now, just cut it out ready to replace lol
Oddly enough the thing I most struggled with was removing the plastic tube that the tank filler breather goes through - I can't get it out?! :confused: Needs removing as there's rust around that too. (In the picture of the etch primer on the right)
thats nothing lol
good progress iian
Some good progress on the engine today, with a nice visit from Draper to help me strip the head! :)
Head with valves etc removed:
http://iainel.co.uk/images/forums/NovaWIP2/424.JPG
Haynes told me to put these in oil so they don't drain?
http://iainel.co.uk/images/forums/NovaWIP2/425.JPG
http://iainel.co.uk/images/forums/NovaWIP2/426.JPG
Removed the water pump to find this! Nasty stuff, hopefully I clean it up nicely:
http://iainel.co.uk/images/forums/NovaWIP2/427.JPG
http://iainel.co.uk/images/forums/NovaWIP2/428.JPG
Sump off:
http://iainel.co.uk/images/forums/NovaWIP2/429.JPG
http://iainel.co.uk/images/forums/NovaWIP2/430.JPG
http://iainel.co.uk/images/forums/NovaWIP2/431.JPG
Got bored of the engine so decided to try the Corsa double joint on the Nova column, as I'm tempted to not bother with the power steering now. Much longer so should fit easily:
http://iainel.co.uk/images/forums/NovaWIP2/432.JPG
http://iainel.co.uk/images/forums/NovaWIP2/433.JPG
That is just why you need anti freeze!Quote:
Tappets wise, you want them to drain out, knock the moveable center out so you can get clean oil in there( take it apart then put in clean oil and push your finger in the hole, this pushes clean oil thru and makes sure theres no crap in there) Then you'll have nice quiet good tappets.
lol @ tappets... Hydraulic Followers Benn, Hydraulic Followers
We're not talking about Fords here lol
Everyone calls them tappets. Never ever heard anyone call them Hydraulic Followers.
hydaulic followers.;)
good to see you ditched the corsa PAS idea ;)
Plenty of time to change my mind again before I weld the mount in lol
hydro buckets lolQuote:
I call them hydraulic tappets! lol
