There's just enough room for the down pipe etc mateQuote:
Originally Posted by Nova_Tek
david.
david.
well i hope to see you two there at some point this yearQuote:
Originally Posted by blue_peg_16v
david.
this look well cool when i seen it today really like the orange mate.
looks good mate. any idea when the engine will be here?
So, if you're running a VXR Turbo on a 3.2 engine, what sort of management system are you going to use?
soon as the couier gets back to me i'll let you know mateQuote:
Originally Posted by let_nova
cheers
we running the standard c25xe on 5 psi mate......well untill we find out how much boost it can run without knock then it might have the timing retarded.Quote:
Originally Posted by Dod
david
well we've been cracking on over the weekend but i didn't get round to taking pics apart from the down pipe after welding and wrapping.
We have got all the wiring finished off, turbo feed pipes welded up and wrapped along with the down pipe, fuel lines are finished off with a black top race fuel reg and gauge, high pressure in-tank pump to replace the nova SPI pump, we have fitted a set of C20LET yellow injectors which should see us ok, we are just about finished the exhaust system, we went for 3" all the way through (including silencers) until it reaches the rear where it splits to 2 x 2 & 1/8" back boxes coming out the middle.
all suspension, bearing type tie bars and poly bushing complete.
The only real things we need is;
1 meter of 3" pipe to finish the system
turbo oil feed pipes,
fittings for external oil cooler (binned the water type)
fit the innovate wideband
intercooler piping to turn up so we can fit it all up
fit shafts and brakes then refit the front end!
http://img.photobucket.com/albums/v8.../Image0367.jpg
I'll try sorting some pics out later in the week
David.
see now thats just silly!
but thats what we like to see *thumbs up*
it is a bit sill to be fair but i love it ha ha
